First time installation. Help
Old Mar 12, 2007 | 01:24 PM
kalel527's Avatar
kalel527
Default First time installation. Help
I have a 1998 Mustang with the seperate tape deck and Cd heads. The CD player doesn't work and I want to replace the factory radio with an aftermarket Sony Xplode. I know Iwill have to bypass the factory amp but I'm not sure what harness I will need and exactly how to bypass the amp. I thought I could bypass it using the standard connectors that are located behind the radio, but that didn't work. So how do I do this? Any help would be greatly appreciated.
Old Mar 12, 2007 | 11:18 PM
ttocs's Avatar
ttocs
Default RE: First time installation. Help
your best bet to match up a hrns is to pull the deck and take it to a shop.
Page 2 on my sig shows how I integrated into a '94 mach system.
Old Mar 13, 2007 | 03:00 AM
MustangMike2001's Avatar
MustangMike2001
You don't HAVE to bypass the factory amps. You can if you want to use a four channel but with the right harnessyou can still use the factory system. It is hard to find the right ones though b/c people get confused with all the different Mach setups. Let me know what you have and I can probably tell you the right one to buy. Also Sony Xplods are pretty crappy headunits. I would suggest looking into somthing else unless you just already have it.
Old Mar 13, 2007 | 03:05 AM
ttocs's Avatar
ttocs
I bypassed the factory amp for the tweets and used some cross overs. IT sounds alot better IMO.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
