Amp Bad?
Old Apr 23, 2007 | 10:57 PM
Wynn's Avatar
Wynn
Default Amp Bad?
I got a Kicker 2 channel amp that I want to bridge to one sub. The left speaker output works good. The right speaker output is not working. I hooked up the sub to just the right output to mess around with it. I adjusted the gain thinking that could be the problem, but it made no difference. I have RCA's running from both jacks in back of my H/U and tried every combination trying to make it work. I went and got an adapter to bring 2 into 1, but I couldn't figure it out. Also, I have the white jack from the H/U to white on amp and red to red, but red from H/U will power white on amp. I know this sounds confusing but I really would appreciate a little help. Thanks in advance.
Old Apr 23, 2007 | 11:39 PM
seight311's Avatar
seight311
Default RE: Amp Bad?
You could have easily blown one channel. And yes your paragraph is relativly confusing.
Old Apr 23, 2007 | 11:41 PM
Wynn's Avatar
Wynn
Is there anything I can try to be sure? When I bridge the pos. right to the neg. left it works fine
Old Apr 23, 2007 | 11:45 PM
ttocs's Avatar
ttocs
try switching the red rca into the white and see if the input to the amp is bad. Otherwise take it to a local shop and have them bench test it to be sure.
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
