96 GT installing HU problem
Old Dec 5, 2004 | 07:40 PM
JJRadiant's Avatar
JJRadiant
Default 96 GT installing HU problem
If anyone can help me please, i am teh uber noob at car stereo. I have a 96 GT w/ mach 460 stereo. I got the harness hooked up perfect and the deck will power up. I can't seem to get any audio though. I have a plug that will go into one of the ones out of the back of the stock amp but i don't know where to plug the other end into. I AM PULLING MY HAIR OUT WITH THIS. If anyone has had this problem or knows how to fix it, PLEASE help me. Plus I have a huge date tomorrow night and I really need to get my cd player installed and dash put back together before this chick freaks out when she sees my jacked up interior. THANKS. JJ
Old Dec 6, 2004 | 12:07 AM
danclint's Avatar
danclint
Default RE: 96 GT installing HU problem
I have the exact same problem on my '95 GT without mach 460. I only find one plug coming out of the stock amp. I don't know where to plug the other end in. [:@]
I'm glad I could be of some help. [8D]
Old Dec 6, 2004 | 02:29 PM
98stngfrk's Avatar
98stngfrk
First of all are you positive that you got the installation kit for the mach 460 sound system, the kit for the plain radio mustangs will fit just like the mach 460's but it will not work with this system. And you shouldn't have to mess with the 460 amps at all if your just installing a head unit, this may be another problem.
Old Dec 8, 2004 | 05:20 AM
dkubik101's Avatar
dkubik101
If you are hooking up an aftermarket receiver to your stock amps without running new wire, you need an OEM amplifier Adaptor to get sound.
http://www.crutchfield.com/S-LkfRpak...51&I=142C4FDK5
Good luck on your date,
Dave
http://www.saddlebackmustang.com
Old Dec 9, 2004 | 01:17 AM
danclint's Avatar
danclint
I figured it out! For my car all it needed was two extra wires connected. It didn't need the bypass. A blue wire with white stripes coming out of my kenwood deck needed to be connected to the blue wire with white stripes on the wiring harness that we previously thought we didn't need. Hope that helps. Mine is not a mach sound system by the way.
Old Dec 9, 2004 | 07:28 PM
perm102's Avatar
perm102
Do you have the premium sound? I have a 2000 with premium sound (not mach). I thought that I hooked it up right but I was running the speaker outputs to the harness that I bought for it into the factory amp (not good). I had to go and get another harness that would take the RCAs from the new HU and then run them into the factory amp. You might want to find out before you blow the amp or the HU. If you do not have a factory amp then you should be good to go.
djbigskrilla
Sep 20, 2022 01:04 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
Pain.
Aug 7, 2015 10:48 PM
