SUBS WITH STOCK HEAD UNIT
Old Dec 15, 2004 | 07:39 PM
bigracingchris's Avatar
bigracingchris
Default SUBS WITH STOCK HEAD UNIT
if i put subs in my 99 mustang and use the stock head unit how will it sound? if i have to change the head unit how would i set it up because of the 2 different slots, would i get a filler? How much will this cost about?
Old Dec 15, 2004 | 08:42 PM
red2k1gt's Avatar
red2k1gt
Default RE: SUBS WITH STOCK HEAD UNIT
buy a head unit for a buck fifty or around there and put it in yourself and hook up your subs
Old Dec 15, 2004 | 09:29 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
you just need a line out converter, tap into one of the rear speakers after the amp for your input, stock cd player is fine
Old Dec 15, 2004 | 10:21 PM
Jimmz's Avatar
Jimmz
I had my 2 12' subs running off my stock stereo for a while and it sounded good. The thing with the aftermarket deck is that most have a built in amp which gives more clarity, you will lose some bass with the aftermarket deck if it has a filter and amp built in. thats what happend to mine. My subs hit really hard and when I got my deck, the power from my subs was less but the clarity from the components was AWESOME!. I just got a better amp and solved the problem. But to make a system sound good you need to fork out the dough.
Old Dec 15, 2004 | 11:12 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
i just got a new jvc cd player for 150 bucks at circuit city, i watched the guy do the install, it only took him 5 minutes, he didn't f@#k anything up. when i adjusted the bass level, it really kicks hard and my sideview mirrors vibrate alot more than with the stock stereo. im pleased with my purchase.
Old Dec 18, 2004 | 10:38 PM
mattwilliams's Avatar
mattwilliams
I am running 2 12's right now off of my stock head unit. Like MD said u just need a line out converter. Easy install
Old Dec 19, 2004 | 03:13 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
I personally think the stock mach system sounds pretty darn good once you give it alittle more ****
Old Jan 6, 2005 | 03:16 AM
tedness's Avatar
tedness
now are we talking the stock head unit without mach 460? cuz i don't have mach 460 and wanna know if i can run subs without that system.
Old Jan 6, 2005 | 01:17 PM
Pacman's Avatar
Pacman
i have all the parts needed to install the subs with the stock 460. on the line out converter there are 2 wires for the left and 2 wires for the right. i thought i had to tap into both rear speakers???????
which wires do i use if i only tap into 1 rear speaker?
Old Jan 7, 2005 | 02:22 PM
Pacman's Avatar
Pacman
anyone??????????????
