cd installation
Old May 11, 2007 | 12:06 AM
mikeocho's Avatar
mikeocho
Default cd installation
What's up everyone, I have a newbie question. Does anybody have the instructions for cd installation for 1992 5.0 LX convertible. THANKS A LOT..
Old May 11, 2007 | 12:07 AM
mikeocho's Avatar
mikeocho
Default RE: cd installation
Old May 11, 2007 | 03:31 AM
ttocs's Avatar
ttocs
easy car. To remove instert the radio removal keys and gently pry outwards, and then pull.
You will need to look below the radio to see if there is a octagonal metal box with a bunch of holes in it(factory amp).
Check that out and get back to me and we will go from there.
Old May 11, 2007 | 09:34 AM
mikeocho's Avatar
mikeocho
Thank you very much.. Do i have to pry out the panels to put the new dash kit? If i do, how and where to start.
Old May 11, 2007 | 09:35 AM
mikeocho's Avatar
mikeocho
Old May 11, 2007 | 12:56 PM
ttocs's Avatar
ttocs
the only part that will come out of the car is the deck and the pocket below it. See the 4 holes on the side of the radio? Go to a autoparts store and get ford radio removal keys, I think even walmart has them. Insert the keys into the holes on the radio(sometimes on the pocket as well) and gently push them outwards awar from one another, then pull out. If the pocket has holes as well then do one side, then the other. The kit will have 4 holes on the corners of the kit and 4 screws. you just screw that to the dash and mount the radio in the kit.
Again, pull the radio and look below it. If the amp is there we will need to bypass it which is easily done if you know how, or know somebody who knows how
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
