help!!!
Old May 20, 2007 | 08:20 PM
03machyellow's Avatar
03machyellow
Default help!!!
can this sub elemental designs EU-700 (D2) work with a power acoustik amp sl2000 specs are below my friend already has the amp?[*]
2000 Watts of Power (Max)
Number of Channels: 2
4ohm RMS: 370x2
2ohm RMS: 450x2
Mono RMS: 900
Full Mosfet Power Supply
PWM Circuitry
FUll Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
Tri-Mode Capable
Variable Low Pass 40Hz-1200Hz
Variable Hi Pass 150Hz-1.5kHz
18 dB Bass Boost @ 40Hz
Frequency Response: 10Hz-30kHz
S/N Ratio: 97dB
THD: 0.02%
2 ohm Stable Stereo
System Distress Indicator
4 Gauge Power/Ground Connection
Platinum Plated RCA COnnectors
Line Output
High/Low Level Inputs with Floating Ground
V-Angled Transparent Terminals
Remote Dash Mount Bass **** Control
Old May 20, 2007 | 08:32 PM
seight311's Avatar
seight311
Default RE: help!!!
You want to run a "2000" watt amp to a 6" woofer?
Or should I say a 500 watt amp to a 6" woofer.
And I have no idea if your friend has that amp, why are you asking me?
Old May 20, 2007 | 08:36 PM
03machyellow
Default RE: help!!!
which one would be better? trying to stick with ed nobody we know has had them and want to give them a shot before changing amps and the whole deal
Old May 20, 2007 | 08:39 PM
seight311's Avatar
seight311
Default RE: help!!!
So what do you have right now (amp) just that power acoustik. What box are you planning on making, what kind of car is it going in, do you have a budget?
Old May 20, 2007 | 08:42 PM
03machyellow
Default RE: help!!!
he has a 2002 gt with the mach system removed, going to have a fiberglass box made for it. that is the only amp i know he has other than some bazooka one that is complete crap.
Old May 20, 2007 | 08:43 PM
seight311's Avatar
seight311
Default RE: help!!!
Old May 20, 2007 | 08:44 PM
03machyellow
Default RE: help!!!
somewhere around 120.00 perferred trying to get him to spend a little more but has to pay to have a box built and everything
Old May 20, 2007 | 08:53 PM
seight311's Avatar
seight311
Default RE: help!!!
http://www.edesignaudio.com/edv2/pro...products_id=31
Remember you can choose a black or silver cone.
GEt the Dual 4 ohm version and wire like so...
And not that that amp is obserdly hih in power but the power it is putting out, isn't super clean so you may want to consider just running one channel, I wouldn't suggest bridging the amp.
Old May 20, 2007 | 08:54 PM
seight311's Avatar
seight311
Default RE: help!!!
Also let him know there is free shipping. Also check on getting some or any sound deadening. Even just getting like 15 cubic feet, will cost him $15-20, it's well worth it.
Old May 20, 2007 | 08:58 PM
03machyellow
Default RE: help!!!
the sound deadoning from them is as heavy as the dynomat or is it lighter?
