Two door speakers not working
Old Jun 26, 2007 | 08:19 PM
markie629's Avatar
markie629
Default Two door speakers not working
Okay, so I was trying to install an amplifier and a subwoofer in my 01' GT with a Mach 460 system, and discoverd that my front two door speakers are not working. I know that both speakers work as I've check them, but they do not make a sound at all. What could be the problem?
Wiring diagrams are impossible to find for these things
also, anyone have any tips on installing an amp? I have power and ground but no idea where to find a remote wire to turn it on.
thanks
Old Jun 26, 2007 | 10:47 PM
ttocs's Avatar
ttocs
Default RE: Two door speakers not working
It sounds like the amp for your front subs cut out. Check your fuses and remote turn on connections if the factory radio has been removed.
you can use any wire that has +12v on it with the key on. There is one behind the radio.
Old Jun 26, 2007 | 11:42 PM
markie629's Avatar
markie629
gotcha,
anyone have any ideas as to being able to tie into a 12volt sourse in the trunk for the remote?
Old Jun 27, 2007 | 01:44 AM
Mthd11's Avatar
Mthd11
probably need a aftermarket deck and have to scrap the 460 but to my knowledge....the remote wire that your looking for to hookup would normally come off the decks harness, but since you have the stock deck idk.... an alternative might be trying to hook up the remote wire to a 12v switched on source... not sure if that would work though
Old Jun 27, 2007 | 02:53 PM
markie629's Avatar
markie629
any 12V source that comes on with the accessories will be fine. I was DRL's but that might just be head aches waiting to happen.
oh, for the record, one of my amps blew. i opened it up and found a fried resistor so i guess this looks like i need to buy an entire new one :\
Old Dec 6, 2020 | 08:16 PM
Luiscm's Avatar
Luiscm
quick question, I just got a 2006 ford Mustang, and the lower front door speaker are not working, the top ones and rear works perfect, the car has a sony screen to control de radio and music, how I can make them work again, what I can do?
Bullet 67
Sep 18, 2015 08:00 AM
Tyoung68
Aug 25, 2015 04:31 AM
clevelandcat
Aug 24, 2015 01:18 PM
69FB
Aug 18, 2015 08:50 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
