Curious
Old Jul 22, 2007 | 05:34 PM
NotFingflyinnow's Avatar
NotFingflyinnow
Default RE: Curious
To add any kind of amp or subwoofer, do I have to hange out the stock radio?
Old Jul 22, 2007 | 05:56 PM
PReal's Avatar
PReal
Default RE: Curious
You don't have too, but I highly recommend it.
Old Jul 22, 2007 | 08:56 PM
seight311's Avatar
seight311
Default RE: Curious
As in you dont have to life or death, but yes essentially, you have to/you will if you want to utilize anything else your purchase for your car stereo.
Old Jul 23, 2007 | 11:23 AM
NotFingflyinnow
Default RE: Curious
Point taken.
Old Jul 23, 2007 | 12:05 PM
laserred38's Avatar
laserred38
Default RE: Curious
It is only a matter of time before the Crap 460 breaks anyway, or eats your CDs. A new head unit not only gives you WAY more options for adding stuff on later and tuning capability, but more importantly, it gives a MUCH cleaner signal to your amps. If you have installed any other kind of part on your car, you can probably install the whole system yourself. Just take your time and dedicate a weekend to do it. Just and FYI, we usually forget to mention this to people...we usually recommend 6.5" components for the front so you will need to make an adapter ring for the 6.5 to fit in the stock 5x7 opening. No trouble at all...very easy and you can use your old speaker as an outline to trace.
Old Jul 23, 2007 | 12:28 PM
NotFingflyinnow
Default RE: Curious
Yea, Thanks for the heads up on the adapter ring. That wasnt mentioned earlier and would have probably had me back here half way throught the project
Old Jul 23, 2007 | 01:16 PM
laserred38's Avatar
laserred38
Default RE: Curious
YW. I always forget that part because it is so simple. But I at one point, was baffled on how to get a "round peg" into an "oval opening".It's alearning process .
Preal has had a very interesting suggestion. He said he has used clipboards (yes the thing you write on) to make the adapter rings. If you think about it, they are very cheap and a lot stronger than plain MDF. I'll let him explain how to trace and cut out the rings, but it is not very hard at all.
Old Jul 23, 2007 | 01:34 PM
PReal's Avatar
PReal
Default RE: Curious
It is as easy as tracing the oringinal speakers and marking the holes. Tracing the new speaker. Then you cut out the oval shape and the circle inside it.
The cheap wood looking clipboards at wal mart are made of hdf, and are great for making adapters!
Old Jul 23, 2007 | 02:04 PM
NotFingflyinnow
Default RE: Curious
Good to know, Clipboards beware.
Old Jul 23, 2007 | 02:05 PM
laserred38's Avatar
laserred38
Default RE: Curious
See? Easy as pie. Only thing I was wondering, shouldn't you try and line up one of the mounting holes on the new speaker with the mounting holes on the 5x7 adapter? So that the adapter and speaker are mounted to at least one of the same locations?
