looking to upgrade mach 460 amp
Old Jul 31, 2007 | 03:17 AM
wraaaa's Avatar
wraaaa
Default looking to upgrade mach 460 amp
I'm replacing my stock headunit on my 2001 v6 with a carPC that I'm in the process of building. If you're interested, I'm pretty much modelling my PC after this install. Same screen, same placement, similar hardware.
Since I will need to buy a small amp to power the tweeters because I'm removing the headunit which powers them, I have decided I might ditch the 2 amps that power the 4 mids too. Will this Profile AP1040 be better than the Mach 460 amps for the stock speakers? Will it be able to power all 8 speakers (the 4 mid speakers and the 4 tweeters), or will I still need to install more than 1 amp to power everything?
Old Jul 31, 2007 | 01:58 PM
ttocs's Avatar
ttocs
Default RE: looking to upgrade mach 460 amp
the stock speaker do not work well with aftermarket amps....... If you are going to pull one or the other you will end up pulling both. The stock speakers are not work keeping to be honest...
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
