How too.
Old Aug 4, 2007 | 06:09 PM
Eric32's Avatar
Eric32
Default How too.
I have the 6 cd changer and the cd player cant play cds no more, so I am trying to take the cd player but i dont know the right way to take off the thing thats around the cdplayer and the vents. So if any can help me out that would be cool.
Old Aug 4, 2007 | 06:10 PM
ScottXL's Avatar
ScottXL
Default RE: How too.
ORIGINAL: Eric32
Which CD player is?
Is it the stock one?
And, if you can get pictures that'd probably help, too.
Old Aug 4, 2007 | 06:25 PM
Eric32's Avatar
Eric32
It is the stock one.
[IMG]local://upfiles/76366/38911B6669D14A0682076F20257C0E85.jpg[/IMG]
Old Aug 4, 2007 | 06:41 PM
ScottXL's Avatar
ScottXL
I believe there's 2 bolts underneath the unit that unscrtew and that might take it out, but I'm not sure.
Another way to do it is by taking the panel off. That's achieved [And believe me, it is an achievement, it's pretty hard from past experience] by unscrewing bolts on either side of the console. They should be hidden underneath another pannel, so you need a wrench or two, and they should come out. I believe once you get one off, the rest of the bolts will be shown. Again, I'm not too sure.
I've yet to take my 'stang apart.
But that's how the rest of the cars are. Just get down and look on the bottom of your panels and underneath them. You should find the starting point.
Old Aug 4, 2007 | 08:50 PM
Eric32's Avatar
Eric32
Thanks I will look around.
Old Aug 4, 2007 | 11:26 PM
Bastinado's Avatar
Bastinado
Looks like my car, except mine is a manual.
To take it out you have to first remove two trim pieces. They both snap into place, so you'll need a screw driver. Pop the trim around the shifter off(slim screw driver, very carefully otherwise you'll scratch our plastic.), then pop off the silver trim with the vents and the 3 control buttons(use screwdriver as needed.). After that, you will see two screws that are black right below the head unit. They were covered by that silver trim piece, unscrew and you can remove the head unit.
Good luck with the new head unit! What are you picking up to replace it anyways?
Old Aug 5, 2007 | 10:43 AM
Moose62's Avatar
Moose62
Here is a postfrom a guy who is upgrading for an Ipod installation. He has step by step with pictures on how to remove the unit. Hopethis helps.
http://www.jtephoto.com/mustang/idio...de/Idiots.htms
Old Aug 5, 2007 | 12:22 PM
Eric32's Avatar
Eric32
ORIGINAL: Moose62
Your link does not work.
Old Aug 5, 2007 | 03:36 PM
Eric32's Avatar
Eric32
Well I got the trim thats around the cd player, but I think I messed up one side of the air vent.
Old Aug 5, 2007 | 06:48 PM
Eric32's Avatar
Eric32
I fix my cd player in my car. Thank you to everyone who help me
