Need some assistance,
Old Aug 12, 2007 | 06:55 PM
ScottXL's Avatar
ScottXL
Default Need some assistance,
I have a 4-channel 520-Watt amp, and 2 250-watt subs. Do I have to bridge the channels to get the 250+ watts to each sub, or will it automatically give all the juice to whichever ones I wire 'em into?
<3
Old Aug 12, 2007 | 07:37 PM
PReal's Avatar
PReal
Default RE: Need some assistance,
You will have to bridge channel 1 and 2 to one sub, and channels 3 and 4 to the other.
amps are not very smart like that. Thier circuits are stamped to perform a certian way and they really cannot adapt.
Old Aug 12, 2007 | 07:46 PM
ScottXL's Avatar
ScottXL
ORIGINAL: PReal
Yeah, that's what I thought.
I have a dual-voice coil... so, do I run a set from Channel 1 to Coil 1, then Channel 2 to Coil 2, and same with the second sub?
[When I say Dual-voice coil, I mean I have 2 sets of positives/negatives, I dunno if that's what the dual voice coil is or not... but that's what I'ma call it]
Old Aug 13, 2007 | 08:16 AM
PReal's Avatar
PReal
That depends on the VC resitance of you subs. Are they DVC 2 or 4ohm subs.
Old Aug 13, 2007 | 04:24 PM
ScottXL's Avatar
ScottXL
ORIGINAL: PReal
2-ohm :\
Old Aug 13, 2007 | 04:28 PM
PReal's Avatar
PReal
If each coil is 2 ohm, you will need to wire the coils on each sub in series to get a 4 ohm load for each sub and then wire it as described above.
That should work great with your amp as long as it is bridgeable.
Old Aug 13, 2007 | 06:16 PM
ScottXL's Avatar
ScottXL
ORIGINAL: PReal
Alright, I didn't really get that. Does the amp have a certain setting/wiring config to get a 2ohm load for each set of wires?
I have to hit up the manuals, I guess.
Old Aug 14, 2007 | 12:56 PM
PReal's Avatar
PReal
Read the info sticky, and every manual you have. For some people this is intuititve, for others you need to read!
robcy
Suspension
Oct 27, 2015 11:14 PM
ChampInSD
Oct 2, 2015 04:55 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
Sep 2, 2015 08:40 PM
Hillbilly1968
Aug 19, 2015 12:03 PM
