equipment
Old Aug 22, 2007 | 07:00 PM
cam2904's Avatar
cam2904
Default equipment
Well went to the shop and had some equipment installed today. New Deck, Mid Bass, Signal Processor. Just have to get a smaller version of my component set. My 6.5's will not fit even with a spacer so have to go with 5.25. Oh and here is the equipment installed will have pics up later in the week.
Eclispe AVN 5500
Memphis 8" Components
Audio Control EQS
Next time I go to the shop will have components installed and probably get some sound deading done.
Old Aug 24, 2007 | 10:29 AM
PReal's Avatar
PReal
Default RE: equipment
Very nice setup.
What do you mean the 6.5's won't fit? If you have a 6x8 hole making a 6.5 fit is a damn easy task.
Old Aug 24, 2007 | 06:04 PM
jakeachy's Avatar
jakeachy
ORIGINAL: cam2904
Eclispe AVN 5500
Audio Control EQS
somebody did their homework. good choices.
Old Aug 24, 2007 | 08:35 PM
laserred38's Avatar
laserred38
Where did you have the 8's mounted? What amps are you running?
Old Aug 25, 2007 | 09:06 PM
cam2904's Avatar
cam2904
The 8's are mounted in the doors. I had the stock grille put back on in place. For now I am running a memphis belle (small) but I might get a small two channel memphis to power the 8's.
Old Aug 26, 2007 | 01:25 PM
laserred38's Avatar
laserred38
Nice, so why aren't you mounting the mids in kick panels then? Where are you having trouble fitting the 6.5s?
Old Aug 28, 2007 | 05:13 PM
cam2904's Avatar
cam2904
I would mount the 6.5's in the kicks but my stang is a stick. In the upper part of the door is where the 5.25 is going.
Old Aug 28, 2007 | 05:24 PM
laserred38's Avatar
laserred38
Oh ok, so kind of a '05 and up styled-3way set up? 8's in the lower doors, 5.25's in the middle, tweets up top?
Old Aug 30, 2007 | 09:18 PM
cam2904's Avatar
cam2904
Finally uploading pics enjoy
Old Aug 30, 2007 | 09:27 PM
cam2904's Avatar
cam2904
another pic
