Blown Speaker - Mach 460
Old Sep 4, 2007 | 04:24 PM
raginglunatic77's Avatar
raginglunatic77
Default Blown Speaker - Mach 460
I just bought a 1996 GT with mach 460 and the right front speaker is blown (the black one by the window at the top of the door not the one in the bottom of the door). Does anybody know where I can buy just that speaker, not the whole set? And for now can someone tell me how to open it up and disconnect it so I don't have a loud hissing noise?
Old Sep 4, 2007 | 11:48 PM
MU71L4710N's Avatar
MU71L4710N
Default RE: Blown Speaker - Mach 460
thats ur tweeter. junkyard or ebay.
Old Sep 6, 2007 | 06:13 PM
cornonthecobb's Avatar
cornonthecobb
I would recommend getting a better one. Probably cheaper. CHeck out woofersetc.com or crutchfield.com .. i just replaced all the stock speakers in my mach system and they sound great
Old Sep 6, 2007 | 10:51 PM
ttocs's Avatar
ttocs
That speaker is a 4 ohm speaker so it will be easy to replace if you want to upgrade as all aftermarket are 4 ohm. I am not using my old ones if you want them? to disconnect them you will more then likely have to remove your entire door panel. You can pull the grill off but I don't think it gives you access to any wires, the stock connection is just below the door panel.
Push down on the top corner of the tweeter and then push in towards the center of the car and the top should snap off. Now push the bottom down and it should also release. You might be able to remove the speaker and disconnect it that way. What ever you replace it with should have a high pass cross over on it.
Old Sep 11, 2007 | 04:21 PM
96_gt_convert's Avatar
96_gt_convert
Still have the front door subs?
Chris
[align=left] [/align]
Old Sep 11, 2007 | 05:36 PM
ttocs's Avatar
ttocs
I replied to your mail. Just make it worth my time to box them and go to the post office and they are yours.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
