Power Wire for Subs
Old Sep 9, 2007 | 10:38 PM
FordMustang0288's Avatar
FordMustang0288
Default Power Wire for Subs
How's it going?
I'm just curious if anyone knows of a how-to for running the power wire from battery to trunk for subwoofers.
Thanks!
Old Sep 9, 2007 | 10:53 PM
jakeachy's Avatar
jakeachy
Default RE: Power Wire for Subs
oh baby, its soo sticky.
Old Sep 10, 2007 | 03:21 AM
ttocs's Avatar
ttocs
welcome to the forum, don't take it personal when hiss makes you cry. Check out the sticky on the top of the page.
Old Sep 10, 2007 | 03:39 PM
seight311's Avatar
seight311
Sticky icky
Old Sep 10, 2007 | 04:44 PM
FordMustang0288
Alright, maybe I should rephrase the question. I was in a rush last night when I posted that.
I've seen the sticky, and actually found an empty grommet in my firewall. Thats not bad at all. What I was actually looking for, is where people have ran the wires? Especially once it gets to the back seat...I don't really just want to tuck the wires on the side.
Sorry if I wasn't too clear, but thanks for the replies
Old Sep 10, 2007 | 05:00 PM
stangant's Avatar
stangant
run the wires down the kick panel and u will want to take out the back seat it makes it so much easier. u will run the wires under the back left side panel. there is then a big hole when u take out the left side trunk panel that u can run the wire thru. this is the best way to hide everything also there is a ground when u take that trunk panal off so it all works out good.
Old Sep 11, 2007 | 09:38 PM
FordMustang0288
Not to get too needy, but exactly how would the rear seat bottoms come off?
Old Sep 11, 2007 | 09:44 PM
tom44vip's Avatar
tom44vip
You guys are talking about the 05 and up models right?
If so what exactly is this trunk panel you are talkin about?
edit: if this is the 05 and up model, there are two tabs underneath the rear seats that you need to push and the seats pop right up
Old Sep 11, 2007 | 10:05 PM
stangant's Avatar
stangant
in 99-04 there are two tabs to push in aswell
Old Sep 11, 2007 | 11:34 PM
seight311's Avatar
seight311
In mine (94) if you run your fingers along where your seat meets the carpet, basically where your calf is if you sit in the backseat, run your fingers along there and you will find 2 spots where the seat connects to the body of the car, take two screwdrivers put one on each side of the thing and pry itand it'll pop out.
