Mach 460 question???
Old Sep 22, 2007 | 08:30 PM
S281_225's Avatar
S281_225
Default Mach 460 question???
Is the headunit out of a 2004 Cobra (CD-6....Mach 460) crossed over to only play highs?
(Trying to swap out stock for stock, this is my winter beater.......CD-6 was a freebie)
Tried to install in my Explorer, and had no bass. Used a Metra reverse harness 71-5520. Everything works, just no bass. My Explorer is a 1997, I used the 70-5600 amp intergrator plug and powered up the blue/white wire for factory amp to get output.
Thanks for any help,
Kevin
Old Sep 22, 2007 | 11:36 PM
ttocs's Avatar
ttocs
Default RE: Mach 460 question???
sounds like your not turning on your explorers amps. Check the voltage to see what you have on the remote output. Ford mach radio's like to use a 6v remote turn on where your explorer probably needs a 12v. If you have 6v on the remote wire try then try connecting the Red +12v switched to the remote turn on and the amps should turn on and off with the key.
Old Sep 23, 2007 | 09:00 AM
S281_225's Avatar
S281_225
The remote is hooked up to the red accesory wire. The fac. amp does come on. Just no bass at all with hte Mach (CD-6) headunit when installed. When I plug the original Ford stereo back in the Explorer everything works fine. Do you think there is a crossover built into the (cd-6) radio?
Old Sep 23, 2007 | 02:03 PM
ttocs's Avatar
ttocs
you can tell the factory amps are comming on because of? The power light on the side?
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
