Fat Mat Opinions
Old Sep 26, 2007 | 06:22 PM
PBiddy412's Avatar
PBiddy412
Default Fat Mat Opinions
Hello,
I just recently took my door apart because my window had jumped off the track. Since I took the door panel off, I wanted to put fat mat (dynamat) on my door also. I have two questions though.
First off, is this stuff good enough to get:
http://www.fatmat.com/Rattle%20Trap/...oor%20kits.htm
Second off, the original seal that was on the door, do I need to keep that on the door if I use the fat mat?
Old Sep 26, 2007 | 07:08 PM
BigFloppy's Avatar
BigFloppy
Default RE: Fat Mat Opinions
I got 100ft of this stuff to my Stang, YEAH it's worth it (and I used all but everything covering the Mustang.)
Pain in the A$$ taking the seats out etc, but the after-effects seem to be well worth it
I'm in a vert with Magnaflows so I hear more than the average user does, to me... worth the time (and the effort) installing this stuff
Old Sep 26, 2007 | 07:57 PM
ttocs's Avatar
ttocs
never used that brand personally. Check out browm bread or amazon has had some deals on dynamat lately. I cover it on page 7 I think on my cardomain page in my sig. You should not need the weather sealer if you do it right.
Old Sep 28, 2007 | 12:54 PM
PBiddy412's Avatar
PBiddy412
Thanks guys. I went ahead and got the dynamat off amazon.com. Cost around 60 bucks with a roller since I figured I would need this also.
What kind of knife did you guys use on this? Is it fairly easy to cut?
Old Sep 28, 2007 | 01:47 PM
BigFloppy's Avatar
BigFloppy
Any type of "good" blade will cut the material, it's relatively pliable
Take care doing the wheel-well area, and below the rear seats (convertible anyways)there are a pair of large plastic grommets that you'll need to pull out, insert the mat, cutting out the hole for the grommetsand then put the grommets back in
In the trunk area, there are also plenty of drain holes... make sure you don;t just cover over them!!!
On your doorskin deal, I pulled the plastic outer layer down so it exposed the main doorskin, matted and then replaced the plastic outer layer
Old Sep 28, 2007 | 02:44 PM
PBiddy412's Avatar
PBiddy412
Heh, well I am only doing the doors right now but that will be good reference if I further decide to do the rest of the car so thank you.
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
Mr. D
Sep 17, 2015 08:17 AM
movielover40
Sep 15, 2015 10:37 AM
