Question on an after market head unit.
Can anyone help me out, im in a bit of a snag here. Okay so heres the situation, i just recentley purchased a 98 mustang gt with the mach 460 sound system in it, it sounds good the way it is, yes i know this but i wanna add a after market head unit inside of this. Now, i bought what i thought to beleive the right wiring harness, but i realized only after taking out my radio, the amps have there own plugs in back of the stock unit. My aftermarket stereo does not. Is there any adapter/wiring harness or radio that comes with the set up for the mach 460 system. I want all the same speakers to work, i just want a different head unit. Anyone know any way to do this?
http://www.sonicelectronix.com/item_4455_Scosche+FD03B+-+FD03.html
http://www.sonicelectronix.com/item_4458_Scosche+FDK4B+-+FDK4.html
In the second harness kit you'll only be using the bigger white harness, not the black one. Note the two blue wires (one with a white strripe), those both need to be connected to a seperate turn on wire (the antenna and the actual amplifier turn on wire)
You'll need a head unit with 3 sets of RCA's if you ever plan on adding a subwoofer.
http://cgi.ebay.com/98-04-FORD-MUSTA...QQcmdZViewItem
will this work also? my mach 460 headunit is gone to hell so im just gonna buy a jensen 7inch monitor, but is this what i need to keep my amps on the 03 mach 460? im not sure if these years being different matters, also what did you mean ovalevader when you said he needs a HU with 3 rcas if he ever wants to add a sub? i already have a sub and amp, so am i good with this or what?
ORIGINAL: 03z28eater
just buy the metra 70-1770
buy the metra 70-1770.
then you have the factory harness that plugs into your factory hu.
your aftermarket hu will come with its own harness.
what you do it plug the 70-1770 to the factory harness.
plug your aftermarket hu harness to the back of the hu.
match up the colors of the aftermarket hu harness to the 70-1770.
connect the wires.
here's a sketch.
[IMG]local://upfiles/62236/CA04410BE248457AA3BF5E40971DD9F0.jpg[/IMG]
connect the wires.
here's a sketch.
where can i get the metra 70-1770 at? do i have to buy it online? ive hooked a few cd players up before but none have had factory stuff, ive always changed my door speakers and stuff out.
