Some help please with car audio
Old Oct 3, 2007 | 10:08 PM
s2k's Avatar
s2k
Default Some help please with car audio
Basically I want to hook up a nice sounding system not overbearing" my ear drums are damaged loud " but crisp clear quality sound form my 06 mustang with the shaker 500.
What iam looking for is reccomendations not on brands but the ratings of the speakers/amps/subs i should be looking for.I found out I need 6x8 speakers and a 8 inch woofer in the door. Sorry about the lack of audio experience but iam looking to really learn.
Old Oct 3, 2007 | 10:41 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: Some help please with car audio
What are you talking about the ratings!?
Old Oct 4, 2007 | 09:57 AM
s2k's Avatar
s2k
Like what rms/wattage/ and I should get 2 amps one for the sub which is a mono amp
and then a 4 channel amp for the speakers right?
Old Oct 4, 2007 | 10:55 AM
y2kStangGT's Avatar
y2kStangGT
rms is constant power, which is normally 1/2 of total wattage.
you should look for rms instead of peak watt.
seller will normally try to mis lead you by giving you the peak power.
Old Oct 4, 2007 | 11:53 AM
joeybutts's Avatar
joeybutts
Also, how much are you looking to spend? You definitely want to go by RMS but remember that the specs are merely guidelines to go by, not the end all be all. The easiest setup would be to use a 5 channel, but i like the idea of two separate amps, a 4 channel and a mono amp. Now, the real audio enthusiasts will tell you that you won't really need the rears if you properly do the front speakers. It makes total and complete sense when you think about it and how you listen to music. If you want some very good guidance, be a bit more specific on your questions and look for PReal, ttocs, Hissss and seight to chime in and lend a hand. They are by far the most audio enabled people on this forum that i know of, there may be others but they have helped me and many time and time again with excellent advice and knowledge.
Old Oct 4, 2007 | 08:21 PM
PReal's Avatar
PReal
What is your budget and how much do you want to spend?
We can set you up with a great stereo for the money!
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
iamgobono
Aug 16, 2015 10:50 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
