I fried my kicker cvr
Old Oct 4, 2007 | 09:44 AM
blue stang's Avatar
blue stang
Default I fried my kicker cvr
the other day I smelled something burning and now the sub rattles. I did the math and the amp was pushing 960 watts max. Now i'm looking for a cvx.
Old Oct 4, 2007 | 09:58 AM
seight311's Avatar
seight311
Default RE: I fried my kicker cvr
Why not look for something better?
What kind of amp are you running 960 watts with, im surprised the CVR lasted that long with over 900 watts being sent to it.
Old Oct 4, 2007 | 11:55 AM
joeybutts's Avatar
joeybutts
max being peak, or max being 960 rms?
Old Oct 4, 2007 | 12:10 PM
blue stang's Avatar
blue stang
runninga Duel amp. the amp is rated 460 peak at 4 ohm[sm=headbang.gif]I calculated wrong its 920 watts peak @ 2 ohm. If you know of a louder 12" round sub with more spl output please tell me about it. I want to get the best bang for the buck
Old Oct 4, 2007 | 02:29 PM
blue stang's Avatar
blue stang
Also I'm using a bass slammer box
specs if you need them: http://www.bassslammer.com/products/...mmerBS112V.pdf
Old Oct 4, 2007 | 07:37 PM
ttocs's Avatar
ttocs
in that calculation did you include an ILS factor?
If Lightning Strikes?
The way dual rates their amp they use a high DLS factor meaning that they will make the rated power, if lightning strikes it for that .11113 secs it will put out that 920 watts.......
You blow subs more often by not putting enough ofclean powerto it rather then putting too much power.
Old Oct 4, 2007 | 08:23 PM
PReal's Avatar
PReal
ORIGINAL: ttocs
ILS is the most fundamental rating system for poor quality equipment.
That amp would make a couple thousandwatts peak following ILS.
Old Oct 4, 2007 | 08:42 PM
seight311's Avatar
seight311
Whats your budget for a new poundage distributor?
Old Oct 4, 2007 | 08:49 PM
blue stang's Avatar
blue stang
so I blew the sub because the amp puts out bad sound quality
for a budget, I'm at collage so I can save. right now I have $150.
Old Oct 4, 2007 | 09:07 PM
seight311's Avatar
seight311
Considering a new amp as well maybe?
