Needed: Remote turn-on wire tap & fuse diagram
Old Oct 14, 2007 | 03:11 PM
JMaN05's Avatar
JMaN05
Default Needed: Remote turn-on wire tap & fuse diagram
have any of you wired up subs to your stock headunit yet? where have you run the remote turn-on ( blue wire) for subs? i havent been able to locate a wire that i can easily tap into to get switched(acessory) power. i lso have been able to located a fuse diagram to see what each fuse is. mylast stock headunit tapped vehicle i read the top of the fuse holder lid to find igniton acessory power fuse and tapped into there. ether way is fine for me.
-does anyone havea fuse diagram for a 2006 mustang gt? and location of all fuse acess points.
-any tap point for fuse or ignition/acessory/switched wire for subs?
HLEP IS NEEDED....ASAP!
Thanks!!!
Old Oct 14, 2007 | 08:32 PM
Berry94's Avatar
Berry94
Default RE: Needed: Remote turn-on wire tap & fuse diagram
same problem for me i dont know which wire to connect to for the remote help us out pleaseee!!
Old Oct 14, 2007 | 11:09 PM
ttocs's Avatar
ttocs
I have done it probably hundreds of times but still cannot tell you what wire to use. There is +12v switched that is behind the radio or else a fusebox is great to look in. Even if I could tell you which wire to use you should still verify that wire with a voltmeter or a testlight if there is nothing better to use. EVERY single time I needed to find a wire I grab my meter, no tool box should be with out one..........
Old Oct 15, 2007 | 11:52 AM
JMaN05's Avatar
JMaN05
but what about a fuse? in my last vehicle i just locaed a fuse that said acessory or ignition...not sure. normal small double pin 15amp fuse. worked great!!!! any info would help though.
Old Oct 15, 2007 | 01:27 PM
ttocs's Avatar
ttocs
the fuse box would be fine also. AGAIN take your voltmeter or testlight and check a couple with the key off, then turn the key on and test again. IT would take less time then reading this, and then making a responce. The correct way to do something is not always the hard way.
Old Oct 15, 2007 | 02:32 PM
joeybutts's Avatar
joeybutts
Check my write up on installing subs into a 99-04 vert and apply it to yours. I ran the remote wire into the fuse box under the dash, and put it into the day lamps fuse since that only turns on when the car is on(duh). it was a 15A fuse in my car and worked fine. I don't know which slot it is specifically off the top of my head, but i don't think it would really be a hard thing to google. Good luck.
http://www.allfordmustangs.com/forum...ng-diagram.pdf
Does that help you?
Old Oct 15, 2007 | 06:52 PM
JMaN05's Avatar
JMaN05
thanks to both of you. they are both very helpful. but i dont htink i have a test light anymore...so that would suck for now..
that diagram is a very good thing to know and have. thanks alot. whihch wire would i need to tap into though/> im thinking the battery wire
Old Oct 16, 2007 | 12:26 PM
joeybutts's Avatar
joeybutts
No, I don't think it would be the battery wire cause that would give constant power. You need something that only turns on when the car is on.
Old Oct 16, 2007 | 01:41 PM
ttocs's Avatar
ttocs
he is right. Go to an autoparts store and spend $10 to ensure that you get something that is only on with the key. Then be sure to put the light back in a spot where you can find it next time. It is amust have for any toolbox........
Old Oct 16, 2007 | 05:37 PM
JMaN05's Avatar
JMaN05
i know it has to be a wire that is only on when the car is on..i have done many systems in my time. i was just trying to find out waht wire you guys used. figuring at least 5 people on here would have responded of how they wired aftermarket subs to a stock head unit.
but i will have to pick up another volt meter i guess. which as ttocs stated, is a must.
