what sub box
Old Feb 23, 2005 | 12:46 PM
link1235jeff's Avatar
link1235jeff
Default what sub box
what sub box
sealed
or
ported
for 2 12inch mtx
Old Feb 23, 2005 | 12:53 PM
dustin's Avatar
dustin
Default RE: what sub box
I have a sealed box with two 10" rockford fosgates and I love the sound! Don't know much about boxes though.
Old Feb 23, 2005 | 03:36 PM
98stngfrk's Avatar
98stngfrk
Well it all depens, first of all a sealed box will give you a tighter sounding bass, getting a vented will give you a boomier bass, yet sealed box's are easier to fit into small areas since they don't require as much room, where the other box's have to be larger. If your not worried about space build a vented box, i have seen some cases where 7-10db's can be gained. Thats a big difference.
Old Feb 23, 2005 | 05:48 PM
link1235jeff
so yall saying ported or sealed
for ported will two 2 1/2inch holes be good
Old Feb 24, 2005 | 04:41 PM
Red 5's Avatar
Red 5
I would suggest you go to the MTX website link below and find your subs part number. They give you all the specs and recommendations for the box size and type for your subs.
http://www.mtxaudio.com/caraudio/pro...stall/subs.cfm
Old Feb 24, 2005 | 10:23 PM
HxCory's Avatar
HxCory
Depends what music. If you listen to more rock you would want a closed box. If you listen to more R&B/Rap/Country, I would get a slotted.
Old Mar 1, 2005 | 03:01 PM
meticulousmobile's Avatar
meticulousmobile
sealed sealed sealed sealed......
Old Apr 4, 2005 | 05:13 AM
cxixer's Avatar
cxixer
ported.
Old Apr 11, 2005 | 02:43 AM
gotmineNov04's Avatar
gotmineNov04
Sealed! I have a tendency to tailor the system for what it sounds like inside. Ironically, the more power you put to a sub in an enclosed box, the shallower it should be. I have a single 10" sub in a box that's 13 x 13 x 8 inside dimensions and run 150 continuous rms (multiply that by about 5 for peak). Ported will certainly add loudness, but I'm looking for decent music reproduction.
Old Apr 17, 2005 | 09:25 PM
lrall's Avatar
lrall
"Depends what music. If you listen to more rock you would want a closed box. If you listen to more R&B/Rap/Country, I would get a slotted." Amen
