Have AMP question
Old Nov 20, 2007 | 09:07 PM
KillSwitchNY's Avatar
KillSwitchNY
Default Have AMP question
im trying to determine myamp capability.
i have all infinity kappa interiors
Fronts - 105watt each
Doors - 225watt each>1260w totalmax power>all powered by> Crunch4 channel700watt amp
Rear -300watt each
2 12" Rockford Fosgate Punch HEsubs @ 800w each> 1600w maxtotalpowered by > Kenwood 800w amp
Obviously i wont be running this system at max power always, so im wondering if this setup sounds ok.
oh, and i am going to be running a capacitor. do i use 1 cap for the whole system? or 1 for each amp?
i was thinking of going with a 3 Farad.
**i have a convertible which is why i have 6 interior speakers
im not too good with sound systems wich is why i have so many questions. any help is appreciated.
Old Nov 21, 2007 | 08:48 AM
joeybutts's Avatar
joeybutts
Default RE: Have AMP question
Do you have any model numbers? Are they components, coax's? All the same? different model kappa's?
Are the watt values peak or RMS?
If you set things up properly, you won't need capacitors.
Old Nov 21, 2007 | 11:44 AM
KillSwitchNY
i will post up model numbers later. but i know for now that the fonts and rears are 2 ways, and the doors are 3 ways. component
and its all peak watts
and no the actual model # are not the same because there are 3 different sized pairs. but all the same speaker.
i would like to run a cap anyway though because im drawing alot of juice with no system as it is!!
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
