INSTALL DOUBLE DIN
Old Nov 29, 2007 | 12:56 AM
Daveo2k6's Avatar
Daveo2k6
Default INSTALL DOUBLE DIN
I am getting this.. http://www.circuitcity.com/ssm/Pione...oductDetail.do
its 4" tall, but i have a 99 gt and i dont have a double din slot. So i was wondering if you guys knew if i could swap out the 2001 to 2004 dash that does have the double din, or if there is a place where i can get a custom one built for my car? thanks guys
Old Nov 29, 2007 | 11:46 AM
Dave5point0's Avatar
Dave5point0
Default RE: INSTALL DOUBLE DIN
I've seen people do the dash swap before, its your best bet.
Old Nov 29, 2007 | 07:22 PM
ttocs's Avatar
ttocs
the swap is as easy as you would hope it would be. hit a bone yard and you can probably score a dash for cheap.
OR I would be happy to show you how to mold it into your dash.
Old Nov 30, 2007 | 03:51 PM
Emanpimpster's Avatar
Emanpimpster
Do you really have to swap the entire dash? Cant you just swap the trim panels from like an 04 and maybe do some modifying?
Old Nov 30, 2007 | 05:43 PM
ttocs's Avatar
ttocs
you swap the center part, around the radio and climate controls.
Old Nov 30, 2007 | 08:29 PM
stang23's Avatar
stang23
i have a 6.5 inch double din
in my stang...all i did was buy the dash kit for like 15bucks
Old Nov 30, 2007 | 08:48 PM
ttocs's Avatar
ttocs
exactly, the car is made to have it depending one what options package you get. The type he has is too small and would require him to cut the opening and mold it in. Yourdash(which simply bolts onto the same place his does) will easily fit a double din.
Old Dec 1, 2007 | 09:57 PM
Dave5point0
Just the center dash and shift boot
Old Dec 5, 2007 | 05:35 AM
Sunadaime's Avatar
Sunadaime
yep i have a 97 just get a 01+ trim and do some cutting of the section at the bottom of the section revilled and place it in. I had a custom bracket but a new bracket might work as well. id show you it but ive had to reinstall my old stuff considering my 6.5 excelon was stolen 1 month after install T_T
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
