Bass problem
Old Dec 14, 2007 | 05:12 PM
ScottXL's Avatar
ScottXL
Default Bass problem
Some may remember me,
I'm the twit that got the CDT (Midrange+Crossover+Tweeter collection), JBL 10" 250RMS [1,000 Max] x2 subs, a JBL 520 4-channel amp, and I got a Boss 1,200 Max monoblock [600 @ 2-Ohm]
Well, I set everything up. I split the monoblock, and to my knowledge, the subs are working fine.
But the front speakers only play bass... and sometimes not play at all.
Everything is plugged in right [I'm nearly positive], and I can't find any setting on my HU that will change it [I have a Pioneer DEH-P6900UB]
Can anyone give me some suggestions? I've switched the RCAs on the back of the HU a few times, enough so that I've tried every different one. Right now, my subs are plugged into my RCA jacks that say "rear" and my front are plugged into my RCA jacks that say "front".
Like I said, all I get from the front is bass, and sometimes nothing at all.
Old Dec 15, 2007 | 10:53 AM
KSUWildcatFan's Avatar
KSUWildcatFan
Default RE: Bass problem
Ttocs should be able to easily help you with this. If he doesn't reply to your post, send him an IM.
Good luck.
-Jordan
Old Dec 15, 2007 | 06:28 PM
silver2006's Avatar
silver2006
check the crossover switch on the jbl 520.
Old Dec 17, 2007 | 09:58 AM
PReal's Avatar
PReal
I'd double check your rca's again. Do you have any sort of crossover on your aftermarket HU?
Old Dec 17, 2007 | 07:05 PM
ttocs's Avatar
ttocs
did you use any of the stock wiring for the speakers?
Old Dec 20, 2007 | 11:32 AM
moparfan74's Avatar
moparfan74
I would check to make sure the speaker wires are not crossed.
Old Dec 20, 2007 | 04:00 PM
Dave5point0's Avatar
Dave5point0
Low pass setting on the amp?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
