Aftermarket Navigation system
Old Dec 20, 2007 | 10:50 PM
DINOmobile's Avatar
DINOmobile
Default Aftermarket Navigation system
I bought a Panasonic Strada Nav system for my 05 GT.
I am replacing my Shaker 1000 head unit. I really
don't know much about audio. Does anyone know if
this will be an upgrade in sound? Will this be as
poweful as the Shaker? I have pasted some of
the specs from their website below. Thanks.
Dino
AMPLIFIER
Max. Power Output
50W x 4(MOS-FET)
Power Output (at 4 and 1% THD+N)
18W RMS x 4
Signal-to-Noise Ratio (reference: 1W into 4)
78dBA
Speaker Impedance
4 ohms
DISC PLAYER FEATURES
DVD Video Playback
Yes
Music CD Playback
Yes
MP3 Playback (CD-R/RW)
Yes
WMA Playback (CD-R/RW)
Yes
AUDIO
Frequency Response (± 1dB): DVD
20Hz - 20kHz
Signal-to-Noise Ratio (IHF, A)
100dB
Dolby Digital Decoder32[/color]33
2ch downmix
Sound Quality
SQ7
FM/AM RADIO
AM Usable Sensitivity (S/N 20dB)
26dB/uV
FM Usable Sensitivity (75, S/N 30dB)
12.2dBF
50dB Quieting Sensitivity (75)
25.2dBF
Number of Presets
18 FM, 6 AM
INPUT/OUTPUT
Video Input (Composite)
1.0Vp-p, 75 ohms
Audio Input
2.0V rms
Video Output (Composite)
1.0Vp-p, 75 ohms
Audio Output/Preamp Output
2.0V rms, 600 ohms
Old Dec 21, 2007 | 10:03 AM
ttocs's Avatar
ttocs
Default RE: Aftermarket Navigation system
it may take a little bit of tweeking but if you do it right it should sound better then the factory radio. I recommend bypassing the factory amps that run the tweeters, but using the factory amps for the subs. When doing this you will need to add capacitors to the tweeters speaker wires to take the bass out of them. Your deck only supplys a 2V RCA output for the subs which is common. The ford sub amplifiers like a little stronger signal so this is easily fixed with a line driver. This is a low level amp that will boost the RCA voltage up a couple of volts and make the subs sound much better.
So with 4 caps and a line driver you will be happy. I cover it on a mach 460 in my 94 gt on page 2 of my cardomain page. I used the factory radio with an alpine for a little over a year before I started the real stereo.....
Old Dec 21, 2007 | 01:21 PM
DINOmobile's Avatar
DINOmobile
Wow, thanks for the advice.
Since, as I mentioned, I am not that knowledgable with this stuff I was hoping I could ask a few more questions.
Are these products (links below) like the ones you mentioned in your post? I notced a farad rating on the capacitors,what sizedo I need? What brands would you recommend?
Should I remove the amps for the tweeters?
http://www.etronics.com/p-16111-lega...p;bname=NexTag&
http://www.amazon.com/Phoenix-Gold-t...424&sr=1-1
Thanks,
Dino
Old Dec 22, 2007 | 01:14 PM
meggaman101's Avatar
meggaman101
Hi ,
I've done the change over ,to the strada on my 2000 GT , VERY happy with it the only thing I don"t like is you have to push the I Agree button every time the unit powers up ,,
I simply spliced in some RCA 'S into the factory amp's ,and installed the voltage regulator to take care of the pop when the unit comes on ,,
the hard part is finding the speed pulse wire ,on the cars computer wireing harness ,
very good navigation prompts and awesome dvd player ,
ttocs write ups were very helpful ,,
No need for caps as they are a gimmic ,,
the line driver is the right one ,,
Old Dec 22, 2007 | 04:36 PM
ttocs's Avatar
ttocs
the caps I was recomending were closer to 100 MICROfarads, not the big style. In this application the cap works as a high pass filter to take the bass out of the tweets, which are probably distorting with any bass at all.
Old Dec 24, 2007 | 10:28 AM
DINOmobile's Avatar
DINOmobile
Thanks for your help guys!
Meggaman, Did you bypass the video lock feature to allow you to use the DVD while the car is moving? Is it done by grounding the e-brake wire on this unit?
Dino
Old Dec 30, 2007 | 10:39 PM
DINOmobile's Avatar
DINOmobile
ttocs,
I had a couple more questions if its all right,
How many inputs/outputs do i need for the line driver? I noticed this varies per model. You mentioned that I should use the sub amps to power my tweeters. Am I to assume that I need an additional output from the line driver for that?
How much extra voltage do I need from the line driver? I am not sure how much the stock speakers need or can take.
Also I noticed stores selling 'Bass Blockers' which seem similar in function to the caps you suggested. They are not rated in Farads but in cut-off (from 150hz and up). Which rating would be comprable to 100 microfarads?
Thanks again for your help.
Dino
bradleyb
Nov 27, 2015 07:50 PM
folivier
Oct 2, 2015 05:34 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sep 24, 2015 09:18 PM
