power help
Old Dec 24, 2007 | 06:22 PM
retrokix's Avatar
retrokix
Default power help
Ok so I looked into it and read up about it in pervious forms and FAQ but I'm still not really sure, so I need a little bit of help. So im running two 12 inch alpine subs
and heres my amp
ok, I just recently got a new alternator and a new batt.
but for sum reason my batt keeps dieing
I checked my wires and connections so I'm really not sure what the problem is, any help?
Old Dec 24, 2007 | 06:53 PM
ttocs's Avatar
ttocs
Default RE: power help
does the amp turn off?
Old Dec 24, 2007 | 07:10 PM
retrokix's Avatar
retrokix
no it stays on,
it just kills my batt. and i always have to jump start it
Old Dec 24, 2007 | 11:07 PM
seight311's Avatar
seight311
You do have the remote wire connected properly I assume...
Old Dec 24, 2007 | 11:12 PM
retrokix's Avatar
retrokix
yes i got it all installed at a place,
but does that cause it drain the batt?
Old Dec 25, 2007 | 12:13 AM
IDRISCKY's Avatar
IDRISCKY
even professional places mess up sometimes, if the remote was hooked up correclty it would turn the amp off [thus your batt wouldn't die]
you should go back and tell them the problem and ask if they'll fix it for free since it's their mess-up.
Old Dec 25, 2007 | 01:34 AM
retrokix's Avatar
retrokix
yah thats true but my amp does turn off and all
but it just seems like my system is draining my batt
or sumthing is
havent figured it out yet
Old Dec 25, 2007 | 10:08 AM
seight311's Avatar
seight311
Hook up a multimeter to your battery, start pulling fuses and see when the draw is around .005 -.010 (Normal Range). Once you figure out which section of your electrical system is drawing after the car is off, check your chilton see where its coming from and keep testing with your mulitmeter until you pinpoint it, go from there.
Old Dec 25, 2007 | 06:45 PM
IDRISCKY's Avatar
IDRISCKY
i highly doubt he has a multimeter seight311
Old Dec 25, 2007 | 10:52 PM
ttocs's Avatar
ttocs
if your amp is not turning off then that is what is draining your battery. If you paid a place to put it in then simply take it back and tell them, don't get yer goey little fingers in it if you didn't install it as you may void your install warrenty on the amp.
