New Hu
Old Dec 26, 2007 | 12:28 AM
Slim2none's Avatar
Slim2none
Default New Hu
Hey guys, Iam just checking to make sure this would work. I have a 95, and am getting rid of the Cass/radio and throwing in a new HU. Iam pretty sure this will be ok. But i want to make sure. http://www.sonicelectronix.com/item_...3B+-+FD03.html
Also, iam looking for a Hu for a 2 channel amp. Dont need something over the top. Just something that will give it the juice. Any suggestions?Thanks guys
Old Dec 26, 2007 | 07:09 PM
ttocs's Avatar
ttocs
Default RE: New Hu
that is the correct hrns if you have a mach460 system, and you have a deck with high voltage(at least 4 volts, 8 preferable) rca outputs. if you have the mach system then I would also recommend With that hrns the FDO2B(standard for radio hrns and this again is only if you have teh mach system). If you use this hrns with some capacitors for cross-overs you can bypass the amp for the highs and they will be a little cleaner. I show this on page 2 of my cardomain page.
