Rear Speakers?
Old Jan 9, 2008 | 10:55 AM
MasterIce's Avatar
MasterIce
Default Rear Speakers?
I'm replacing the front speakers and door subs in my 06 coupe and putting in a 3 way setup, along with putting a 12" sub in the trunk. My question is what should I do with the rear speakers? Replace them with coaxials or not use them at all? Would it be possible to put 2 way 6.5" components back there or would that be too much?
I'm just curious as to what you guys have done..
Thanks!
Old Jan 9, 2008 | 11:01 AM
joeybutts's Avatar
joeybutts
Default RE: Rear Speakers?
Supposedly from an SQ standpoint you don't want rear sound. You want the staging to be in front of you as if you were listening live to a band at a concert (the old trusty example). If you would like to put speakers in the back, have them be some sort of low passed speakers playing nothing above 500Hz (i think that's about where you want it). I pulled my rears out and it sounds great.
Old Jan 9, 2008 | 11:02 AM
PReal's Avatar
PReal
Rear fill should be low passed around 400hz if you want them.
I don't use rear fill in my cars and most other knowledgeable people about car audio don't. It is all about your personal preference.
Old Jan 9, 2008 | 12:10 PM
ttocs's Avatar
ttocs
you guys I completely disagree, lowpass? I thought most systems if they use a rear fill for SQ they like to use a bandpass(it allows a band of freq's through) but still allows the front to be the main sound source.
The x-overs on my diamond 3 ways has this option that I am going to try out hopefully soon.......
Old Jan 9, 2008 | 12:38 PM
joeybutts's Avatar
joeybutts
ORIGINAL: ttocs
True...true.... didn't think about that...probably like 100-400?
Old Jan 9, 2008 | 02:08 PM
PReal's Avatar
PReal
ORIGINAL: ttocs
Sorry for my missspeaking ttocs.
Bandpass is the best solution for rear fill. IMO anywhere from 50-100hz up to 400-800hz is an appropriate signal for rear speakers.
The biggest no-no in my opinion is to put tweets in the back.
That is an awesome feature of the diamond crossovers!
Old Jan 9, 2008 | 06:33 PM
MasterIce's Avatar
MasterIce
Good stuff guys....I appreciate it.
Old Jan 10, 2008 | 12:25 AM
ttocs's Avatar
ttocs
I was wondering as I am still kicking and fighting the intire way down into this whole no-rear-fill area........ I am curious how it works as well and can't wait to hear them.
ORIGINAL: PReal
ORIGINAL: ttocs
Old Jan 10, 2008 | 10:22 AM
MasterIce's Avatar
MasterIce
So is the consensus pretty much that, IF you decide to run with "rear fill" that it would be best to run those speakers off of the head unit as opposed to an amp?
Old Jan 10, 2008 | 11:51 AM
ttocs's Avatar
ttocs
Again, the idea of having no rear fill works great for competition grade systems but for every day people the majority of people(except on here) enjoy rear fill so if you like it then I would recommend trying to match the rear speakers to the front as well as with simlar power levels as the front but you can get away with runnin them off of the deck. If you do not like that sound you can always add an amp later.
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
Doogie65
Sep 6, 2015 02:55 PM
