sound when leave headlights on
Old Feb 17, 2008 | 04:09 PM
roushxteam199's Avatar
roushxteam199
Default sound when leave headlights on
Ok heres the deal. I completly rewired a new radio in my car. Im only using two existing wires a ground and a accesory power. I ran a new constant power. But after i installed the new radio my headlight is on dumy sound is not working now. I cutted all the radio wires and tape them up. Is there a wire that i disconected that controls it. any help would be appreciated.
Old Feb 18, 2008 | 11:07 PM
ttocs's Avatar
ttocs
Default RE: sound when leave headlights on
you blew a fuse. NO, we don't know which one and will not read your manual to tell you which one. Don't even bother getting your manual out just start pulling them one at a time and checking them. It will take less time to phisically check each fuse then it will to try and figure out which circuit its in, which fuse that is, ect.....
I suspect you re-ran everything because you could not get the existing wires to work? This was probably because of the same blown fuse.
Old Feb 19, 2008 | 11:26 AM
roushxteam199
i will check the fuses next time i have the stang out. I ran new wires so i would know what is what. The guy before me jerry rigged every audio wire in the car. Its was a pain to identify what wire was what, I just decided it would be easier to run new wires. It made my life that much easier by doing it. I didnt think about the buzzer at the time. Now that i left my head lights on a few times i decided to finallly check into it. thanks for the help
Old Feb 19, 2008 | 08:38 PM
roushxteam199
haha fixed you were right. I thought i had checked all the fuses but apearantly i missed one. This one was hard to spot. I just started to pull them out and came across it. The funny thing is its just barely broken and was hard to spot. Thanks for helping me.
Old Feb 20, 2008 | 02:51 PM
ttocs's Avatar
ttocs
glad I could help, thanks for lettin me know.
Did you see what circuit that fuse was in? It is sometimes funny to see that the windshield wiper fuse blew and took the other circuit with it.........
Let this stand as an example if we can, start simple, check the fuses, ALL THE FUSES!
StalkerGT
Nov 28, 2015 03:09 PM
folivier
Oct 2, 2015 05:34 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
MustangV6P
Sep 28, 2015 11:00 PM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
