what size speakers
Old Mar 2, 2008 | 07:43 AM
timi's Avatar
timi
Default what size speakers
hello i have an 03 gt with the mach system. what size speakers do i have in the front and back?
thanks
Old Mar 2, 2008 | 11:26 AM
apolnerow08's Avatar
apolnerow08
Default RE: what size speakers
Fronts are 5.5"x7.5" and the tweeters are 2.5". The rear are 5.5"x7.5" also. Verts are 5.5" rounds in the rear.
Old Mar 2, 2008 | 02:05 PM
ttocs's Avatar
ttocs
that is 5 x 7 front and rear and the tweets are 2.5's. You can fit a 6.5 in the opening if you make a baffle.
if you are replacing the mach woofers you will need to replace your deck if you have not already. The mach system uses some funny impedences to make it difficult
Old Mar 2, 2008 | 04:55 PM
timi's Avatar
timi
when i bought my car it came with the jl audio stealth box and a jl 250wt mono amp. i bought a avic-z2 (on it's way) and i'm looking into focal speakers and a jl 4 channel amp to run the speakers but i haven't decided yet what size to get. more than likely i'll have them installed cause i need an amp rack made. i plan on hiding the new tweets inside the mach tweet housing to keep it stock lookn
Sep 30, 2015 12:39 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
