what size fuse
Old Mar 11, 2008 | 12:18 PM
forgotten's Avatar
forgotten
Default what size fuse
I'm getting a hifonics amp that produces 640 watts nominal. What size inline fuse should I buy?
Old Mar 11, 2008 | 01:34 PM
disturbed471985's Avatar
disturbed471985
Default RE: what size fuse
200
Old Mar 11, 2008 | 02:09 PM
forgotten's Avatar
forgotten
Well, I wasn't expecting that.
Old Mar 11, 2008 | 02:30 PM
PReal's Avatar
PReal
If you are trying to protect from a dead short, I'd install a fuse about 1.5-2x the total fuse rating from the amp itself.
Old Mar 11, 2008 | 02:34 PM
forgotten's Avatar
forgotten
ah, well that makes sense.
Old Mar 11, 2008 | 05:02 PM
ttocs's Avatar
ttocs
the amp determines the size of the power wire needed, the size of the power wire will set what size fuse you will need. What size is the fuse in the amp? That fuse is made to protect the amp and that will also help determine what size cable to use. Are you planning on adding or upgrading the amps? This is important to know before you start running power wire or installing fuses
Old Mar 11, 2008 | 05:19 PM
forgotten's Avatar
forgotten
I haven't gotten the amp yet. I was gonna go with 4 guage wire. I don't plan on upgrading the amp or adding another amp any time soon.
Old Mar 11, 2008 | 05:49 PM
Spyder's Avatar
Spyder
This shows you all the things you need to know for (properly) calculating the fuse size along with power wire...
http://www.realcaraudioreviews.com/Articles/Fuses.jsp
Basically, your amp's current draw will determine what fuse to use. That draw, along with the length of wire you plan to run, will determine the wire's gauge.
Also check this one for properly fusing your system:
http://www.bcae1.com/fuses.htm
Edit: Can't spell to save my life today...
Old Mar 11, 2008 | 07:38 PM
RuffCat's Avatar
RuffCat
I have 2 amps. One for subs and one for highs and they have far diff. fuse characteristics so I have the fuses on the amp, two seperate inline fuse holders between the amps and the main fuse on my firewall.
For the basic one amp install, with 600 or so watts and 4 guage power wire, 100-120 amp fuse is more than suffiecient. Besides that amp will probably only produce 400watts peak on a good day.
Old Mar 11, 2008 | 09:08 PM
ttocs's Avatar
ttocs
100 amp is too big for 4 awg, I don't like to go above 80.
