keep blowin in-line fuse
Old Mar 24, 2008 | 03:23 PM
850SN95's Avatar
850SN95
Default keep blowin in-line fuse
ok i've got one DHD subwoofer hooked to my jl 500/1 mono amp o yea and stock radio
and all the gains and settings are at their normal positions and when i turn my h/u up to max (which is at 45) the fuse blows
the highest i can turn it up is about 30-35
any helpful hints as to what might be the problem
Old Mar 24, 2008 | 04:53 PM
ttocs's Avatar
ttocs
Default RE: keep blowin in-line fuse
what size power wire are you running and what size is the fuse?
Old Mar 24, 2008 | 05:09 PM
850SN95's Avatar
850SN95
40 amp fuse and 8 gauge powerwire
Old Mar 24, 2008 | 05:38 PM
850SN95's Avatar
850SN95
c'mon seight or ttocs or the otherr dude hiss
this is freakin killin me softly
Old Mar 24, 2008 | 07:37 PM
Spyder's Avatar
Spyder
Well,
You can do two things...
Number one you can understand howit works and do the math for yourself:
http://www.realcaraudioreviews.com/Articles/Fuses.jsp (Comes out to a 52A Fuse)
Number two, you can read the owners manual:
http://mobile.jlaudio.com/pdfs/13320.pdf
Page three... They recommend a 50 Amp fuse.
And you should probably upgrade to 4 Ga... You're borderline with that 8Ga wire...
Old Mar 24, 2008 | 08:25 PM
850SN95's Avatar
850SN95
thanx dude, i read the manual for my amp but i overlooked that part[sm=chairshot.gif]i'll be sure to try an 50 amp fuse tomorrow, and as far as 8 gauge goes, i've been using it since i had this set-up in my stang and it never was a huge problem, i'll probably wait on the 4 gauge tho cause the 8 is working finejust for now
edit: and now i feel even stupider for just now realizing i bought about 8 40 amp fuses today and i ended up running through half of'em trying to figure out the problemand that was a waste of 5 bucks[&:]
Old Mar 24, 2008 | 09:23 PM
Spyder's Avatar
Spyder
No problem,
But regarding the power cable, think that your fuse was blowing at a 40 Amp draw. Now you will have an extra 10 Amps that the cable must handle. If your run is long, the cable will heat up. Just saying it's better to stay on the safe side of things, after all, 10Ft of cable might be worth $20.00. I'm sure you value your car more than that...
Old Mar 24, 2008 | 09:58 PM
cegha's Avatar
cegha
Just a word of advice but if your gains are set correctly, you shouldn't be turning your headunit all the way up anyways for your subwoofers sake.
Old Mar 25, 2008 | 12:49 AM
850SN95's Avatar
850SN95
soi should be ok with the 50 amp fuse, ya know as far as catching fire and what not? hate to screw up my impala anymore than it already is
the woofer is the last of my worries as i got it for free, im worried about my car and the amp if anything
Old Mar 25, 2008 | 10:43 AM
ttocs's Avatar
ttocs
I think this post has missed a couple of points. What they are trying to say is that you are close to the max current draw on your power wire, hopefully the amp is the only part being powered by that wire? Upgrading fuses is a band-aid over a wound that will not heal.
I just do not want people to think that when a fuse blows, put in a bigger one. I have seen some people do some major damage to their cars by doing this. One guy had a black line burned into his tan interior from the battery, to the amp from doing just this.....
