New Speakers
Old Mar 28, 2008 | 10:02 AM
thatdude305's Avatar
thatdude305
Default New Speakers
I want to put in some new after market speakers. Can i install them or is there a plug that i could buy to hook them up so i could continue to use the amps in the trunk?? or will i have to rewire the entie system. thats not what i want to do. i just want to know if i could purchase a plug to connect the new speakers????
Old Mar 28, 2008 | 02:14 PM
ttocs's Avatar
ttocs
Default RE: New Speakers
assuming this is for the 02 gt in your sig, it is difficult to replace just the woofers of the mach system because they use a strange impedence(8 ohms) were most aftermarket speakers are 4 ohms. You can brighten the mach system up alot with a new deck and some tweeking, and then you can use an speaker you want.
Old Mar 28, 2008 | 03:35 PM
900RR Puzzle's Avatar
900RR Puzzle
Hey ttocs, is there a resistor or something that I can put in parellel or series with the speaker to get the right value for the amp load. I put aftermarket speakers in the doors of my 2002 GT (Mach 460 system) and they cut out if the volume is up past 1/2. I have heard others have this problem, but never heard a solution other than replacing the amps with aftermarket ones.
I really don't want to replace the whole system right now.
Old Mar 29, 2008 | 01:45 AM
ttocs's Avatar
ttocs
you could put a high wattage resistor in there but it will not help you as it will now burn off half of your power from your amp in the form of heat, making your speaker now play with half the power.
This was the reason your system was cutting off at half power. If you replaced your deck you can bypass the amps
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
