Mach Question
Old Mar 30, 2008 | 12:25 AM
wolf39us's Avatar
wolf39us
Default Mach Question
ok so here is my question, I have a mach 460 system setup on my 2000 mustang vert
I sent it to circuit city like an ******* to get an after market HU installed and they decided to mess it all up....first they said that the ford harness was messed up and that they needed to re-wire everything....
then they told me that they wired directly from the headunit to my speakers...so whatever (I didn't do much research at this point)...
after doing a whole lot of using the search button on this amazing site....I am still left with a question
IS it best to utilize the mach 460 stock amplifiers with an adapter OR wire directly to the ORIGINAL mach speakers??
as far as I know the mach speakers are 6 ohm unlike the standard 4 ohm
I'm starting to think that I will probably get the best sound out of using the factory (3) amps
what should I do...they have agreed to fix it....but I'm wondering wether to just tell them to scratch their idea to wire directly to the speakers and make it work this time...or tell them to use an adapter and use the factory amps
the unit I bought has 2 pre-amp outs ...it is the JVC KD-HDR30
Old Mar 30, 2008 | 12:59 AM
ttocs's Avatar
ttocs
Default RE: Mach Question
page 2 of my cardomian page shows what I recommend. Bypass the factory amps to drive the tweeters, but you will need to add some capacitors to keep the bass out of them. Use the factory amps for the woofers.
What deck did you put in?
Old Mar 30, 2008 | 01:03 AM
wolf39us's Avatar
wolf39us
JVC KD-HDR30
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
UrS4
Sep 30, 2015 10:13 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
