I am looking around.
Old Apr 12, 2008 | 10:48 PM
ramoyer1's Avatar
ramoyer1
Default I am looking around.
Ok i drive a 2001 mustang and we all know that they have no trunk room.So i wanna how you guys have you subs set up in there.i have one rock ford 10 now but i want 4 10's or 2 15's in there.i would even do 3 12's.Plz post pics of what you guys had setup so i can get idea for my box set up and amp rack lay out! Thanks so much!
Old Apr 13, 2008 | 01:23 AM
ttocs's Avatar
ttocs
Default RE: I am looking around.
you have a wide range listed there of what you are considering which should be narrowed down easily by what you want out of the system. My box is a little different as I wanted to keep the trunk usable, and wanted something more towards sq over spl, and do not listen to much rap so my box is about 1.6 cu ft that hangs from the rear deck and houses 4 - 8"s. it is on page 7 er 8 of my cardomain page
Old Apr 13, 2008 | 06:12 AM
seight311's Avatar
seight311
With multiples like that your clearly in a phase where you want tons of bass. You should probably get an 18" in a big ol' box, say 4.5 cubemaybe? [sm=badbadbad.gif]Not something too expensive because you will be absoltely sick of that much bass in about a year or less. But get you a good solid amp that you can use for any system you do now or in 5 years.
I still would like to hear what exactly you want, what you listen to, your budget etc.
Old Apr 13, 2008 | 09:10 AM
ramoyer1's Avatar
ramoyer1
I have 2500 that i can spent right now.I want to make it look great and i like rap,and rock. i want to pretty much take up the whole turnk!.I was thinking about putting a sub on the rear deck were the 6x9s are.It would have to be the new slim sub but i thing it would be pretty kool loking with the box hooked to it from the back side
Old Apr 13, 2008 | 09:27 AM
ttocs's Avatar
ttocs
speakers are 5 x 7's all the way around, you can put a 6.5 if you make a baffle to mount it.
Old Apr 13, 2008 | 10:01 AM
ramoyer1's Avatar
ramoyer1
well Then 5x7s.I still need a idea of like the amp rack and the ssub lay out gere are some pics that i kinda like the boxs and i would make them fit in on each side of the tunk behind the tails lights.
http://caraudiofactory.com/single-sl...45df60883c4276
Put one of them on each side and hook them to wall so they dont side out.trim them up with leds.I cant use my spare tire spot i have 1 10lb bottle of go-go juice there.so amp rack would have to be put somewere
Old Apr 13, 2008 | 08:48 PM
ttocs's Avatar
ttocs
have you pulled the backseat yet?
Old Apr 13, 2008 | 09:02 PM
ramoyer1's Avatar
ramoyer1
yes and no. The bottem yes the fold down part no.but i have found 2 setsup that i love so i am going to use both of them together. Here are the links tell me wat u guys think.
Old Apr 13, 2008 | 09:14 PM
ramoyer1's Avatar
ramoyer1
I think i will do 2 kicker l5 or l7 on the back wall (under rear deck)or 3 t1 12" like the last pic of the jls with amps mounted on side! but i still like the mtx set up but i cant find a alt. with more then 110amps. i would need batterys bad!
Old Apr 13, 2008 | 10:05 PM
joeybutts's Avatar
joeybutts
I think one DD Z18 would fit the bill or maybe a 9518g?
