subwoofer upgrade/replacement
Old Apr 30, 2008 | 01:22 PM
ssv6ponypower's Avatar
ssv6ponypower
Default subwoofer upgrade/replacement
So right now I have 2 Infinity Kappa 12" subs and I am looking for a good replacement for these great subs. I want something that can hit the really low hrtz such as 22-25 hrtz yet still have a really good response for that quick bass beats in rock and something that is very realible since i listen to them a lot and I am wondering what you guys think because I am undecided on a lot of subs. I am looking to spen about 200-250 a sub so let me know what 12" subs you guys really like thanks a bunch
Old Apr 30, 2008 | 01:45 PM
PReal's Avatar
PReal
Default RE: subwoofer upgrade/replacement
You want to hit 22hz???
What is your reasoning behind that statement?
Any sub or woofer can hit 20hz, but flat response down to 20hz is generally reserved for home theatres as music is not played that low and the only things that is close to that frequency is that of a cannon or explosion.
What type of enclosure will the subs go in? What type of amp will be powering them?
Old Apr 30, 2008 | 06:27 PM
ssv6ponypower
i meant to say that in the ratings of the sub it has a responze of 22hz so that it can really produce the lows fairly easy and they will be in a sealed box with a rockford fosgate 1600watt amp so each sub gets 432w rms
Old May 1, 2008 | 10:10 AM
disturbed471985's Avatar
disturbed471985
22HZ. Go with AQ havent seen them yet but heard great things about them and if there even half as decent asthere bigger broDD then u should be fine.
Old May 2, 2008 | 12:01 PM
seight311's Avatar
seight311
432 exactly huh?
What's that at 1 ohm?
Old May 2, 2008 | 01:29 PM
tkechris's Avatar
tkechris
get one of these and bridge your amp. :
Pioneer Premier TS-W3001D2
12" 3000W Dual 2-Ohm Subwooferhttp://www.onlinecarstereo.com/CarAu...roductID=18352
StupidTodd
Nov 8, 2005 03:18 AM
mustang_montana
Aug 31, 2005 12:10 AM
jnbishop
May 31, 2005 04:11 PM
link1235jeff
Mar 5, 2005 02:26 AM
bluthdr815
May 5, 2004 04:51 AM
