no sound from amp
Old May 5, 2008 | 10:29 PM
laserredgt's Avatar
laserredgt
Default no sound from amp
hey guys is it possible that the rca's that were put in the back of my mach 460 head unit are not good anymore???i have everything connected and the amp is running fine but no sound out of the speakers...changed subs and amps but still no luck in my troubleshooting..the rca's are my last option...or do you think that my amp is too weak for my sub?? i have a 350x2 kicker running a 12" type r alpine
thanks guys
Old May 6, 2008 | 06:44 AM
seight311's Avatar
seight311
Default RE: no sound from amp
Mach head units don't use RCA preouts, you have a line out converter somewhere. 90% of people run them off a rear channel. Usually they splice into the speaker wire right around the rear deck, I have seen some people splice in up by the headunit as well, rare, but it happens.
Your converter could have went out, if you have no sound out of the speakers as well there is a possiblity you have a problem with a Mach amp, or the power/signal going to it. There are a couple hundred things that could be wrong. Thing that really sucks is that you could just have a wire grounding out somewhere, and factory wiring is all bunched and loomed together.
Old May 6, 2008 | 10:12 AM
ttocs's Avatar
ttocs
we need a list of what is in the car before we can make an educated guess as to what could be wrong. Model numbers and how they are wired, not color shape or anything else.
Old May 7, 2008 | 06:03 PM
JBob250's Avatar
JBob250
i wouldnt buy anything just yet. chances are its just the fuse in your engine bay coming from your battery. take the time on a nice day when you've got some time on your hands to gut and re-install your system. guarantee you'll make it 20% through and you'll figure out what the problem was. this is a good oppurtunity to go and hide all the wires and solder/shrink tube any loose connections, zip tie bundles etc.
have a friend help you out and it'll go quickly and painlessly
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
