Aftermarket Satellite
Old May 9, 2008 | 11:49 PM
BJSHELBY08's Avatar
BJSHELBY08
Default Aftermarket Satellite
Has anybody invented a way to use the factory sirius antenna to connect to an aftermarket player?
Old May 10, 2008 | 02:17 AM
ttocs's Avatar
ttocs
Default RE: Aftermarket Satellite
the end will fit from what I understand.
Old May 19, 2008 | 01:04 AM
JayFi's Avatar
JayFi
I just checked this out today since I am replacing my shaker 500 with a pioneer head unit w/xm. Took my XM MyFi out to the car and plugged it into the trunk mounted antenna. Note that I had to remove the plastic casing from the antennas connection to do this.
Everything worked fine, but if you're planning on mounting your aftermarket sirius/xm tuner farther away than the factory location you're probably going to need an extension for the antenna.
lincolnshibuya
Oct 6, 2015 08:45 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
