No power to amp! grrrrr
Old Jun 21, 2008 | 08:45 AM
k_brayman's Avatar
k_brayman
Default No power to amp! grrrrr
I am a complete dunce when it comes to sound systems and I had my husband connecting everything. I will try to explain the current setup and the problem as best as I can.I have a 2002 GT, premium package with the Mach sound system. 460, I think. 10" subs did NOT come with it. 6-disc CD changer.We removed the disc changer and added a JVC head unit that is connected through a wiring harness. The JVC has a built-in 45w amp according to the store, but the box says, "MOS-FET 50w x 4 (20w RMS x 4)" and I have no clue what that means. lol I have an Explod 1100w 10" sub in a Competition Bandpass fiberglass box (barely fits in the tunk due to height), a mono 800w Explod amp that came attached to the sub (not currently connected), a 2-channel 1000w Insignia amp, and its all wired with Monster cables. Yes, it is a cheap system but I'm trying to get started with the money I have. Please don't suggest I buy "a new *this* or *that*" because I want to work with what I have unless you think it could be a defective part.Sound is not the problem since I get sound to the stock speakers. We ran the power cable straight from the battery to the Insignia amp and we're getting no power at all to the amp. We know it works because we thought the Explod amp didn't work and took the Insignia out of another vehicle to test it. The ground wire has been bolted directly to the bare metal body (sanded the paint off) under the carpet. I'm sure the sub works, but we're just not getting power to the amp. Tried cleaning battery terminals, cutting the power cable and stripping it again thinking we had a bad connection due to the wire itselfand still no power! Please help!!![/align]
Old Jun 21, 2008 | 11:45 AM
CantStopTheFox...'s Avatar
CantStopTheFox...
Default RE: No power to amp! grrrrr
You say the power and the ground are good..........is your remote wire connected??
The remote wire is connected directly to the stereo....it tells the amps to turn on and off when the car is on. This way, they won't always be on.......draining your battery.
If the remote wire is not connected, the amps won't come on
Old Jun 22, 2008 | 07:25 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
+1, sounds like the remote isn't hooked up.
Do you have a fuse near the battery on that power wire? If not kiss your goodbye in a ball of fire.
Old Jun 23, 2008 | 10:43 AM
k_brayman's Avatar
k_brayman
As Carlos Mencia says, "Dee-dee-dee!" ugh... It was the remote wire. I took your advice and ripped apart my dash again and pulled the head unit out. Lo' and behold! There was this little blue wire with a huge blue tag on it that said, "REMOTE WIRE." duuuuh. Got it fixed. Thanks for your responses.
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
