pioneer subs
Old Jul 26, 2008 | 11:22 AM
firestang24's Avatar
firestang24
Default pioneer subs
I've tried using the search function on this site, and for some reason i'm obviously not technical enough to figure it out........
I know it's been suggested, and used before but who has installed the pioneer shallow subs, and how do they sound? it seems that people who have installed them never give their opinions afterwards.
thanks in advance.
Old Jul 26, 2008 | 12:03 PM
bumpinvert's Avatar
bumpinvert
Default RE: pioneer subs
I don't like the shallow subs. It may be because I have only heard them in little boxes, but if this is for your mustang go with traditional style subs with a custom box to fit your needs.
Old Jul 28, 2008 | 06:31 PM
HOLLABACK's Avatar
HOLLABACK
If you go onto youtube.com you can find videos of the shallow subs and how they sound as well. It would help to know what type of installation you would like. If you have an 05+ with a Shaker system and you would like to put these subs in the door, then I can give you an idea of how they will sound. Your bass will be tighter and you will get a little bit more sound out of them. All of this will depend on your entire setup and whether you are using an aftermarket head unit or not.
Old Jul 28, 2008 | 08:21 PM
firestang24
ORIGINAL: HOLLABACK
thanks, i didn't think of the you tube thing. Ihave an 07, and as of now it's stock, I plan on using either a pioneer, or kenwood dvd head unit, and just replacing the speakers. no major amps, or subs. thanks.
Old Jul 29, 2008 | 06:55 AM
PReal's Avatar
PReal
ORIGINAL: HOLLABACK
What can make you say definitivelty that the pioneer shallow subs will be tighter?
Sub size, brand, x-max, and construction are only a small part of the equation. The key to the musicality of a woofer, i.e. tightness, is the install of the woofer.
Old Jul 30, 2008 | 09:15 AM
dsg03gt's Avatar
dsg03gt
jl audio is just coming out with a shallow mount sub i believe it is called the Tw5 and is supposed to be really good..
Old Jul 30, 2008 | 11:23 AM
imthedriver's Avatar
imthedriver
Get a set of Kicker Solo Baric L7's.
Old Jul 30, 2008 | 01:44 PM
firestang24
I'm not looking into jarring the fillings out of my teeth. I also dont want to lose as much of the trunk as i can.
Old Jul 30, 2008 | 02:18 PM
dsg03gt's Avatar
dsg03gt
ORIGINAL: imthedriver
Overrated.. look into the jl's im telling you there great subs..
Old Jul 30, 2008 | 08:02 PM
ttocs's Avatar
ttocs
you will need to add an amp to drive an 8, and I would not run the factory amp to the new speaker......
