Mach 460 Amp Question
Old Aug 9, 2008 | 01:12 PM
5.0LitreSN95's Avatar
5.0LitreSN95
Default Mach 460 Amp Question
Quite simple really, are all Mach 460 rear amps the same? For instance, will a rear amp from a 2003 Mach 460 system work in my 1994 system?
Thanks
Old Aug 9, 2008 | 08:29 PM
ttocs's Avatar
ttocs
Default RE: Mach 460 Amp Question
wow, not sure there. the equipment was the same but I think some of the wiring may be different. If you compair the wire hrns connections and the look the same then you should be good to go but I have never personally done it.
If you have replaced the deck with an aftermarket, you can could just bypass the amps and install a regular set of speakers up front. The majority of the bass from the mach system is in the rear with the enclosure, and adding a set of full range speakers up front you will probably get better sound then the mach.
PaulH2
20
Jan 31, 2016 09:48 AM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
