Mach 460 Front Door splicing
Old Aug 30, 2008 | 08:17 PM
Baef's Avatar
Baef
Default Mach 460 Front Door splicing
Where is the best place to splice into the front doors? I have replaced the speakers, and as I am wiring my amp in I realized (based on diagram) that the two front doors (woofers) are in parallel.
I would like to have the right and left be separate, but am unsure where I can 'easily' splice the wires without trying to run new cables into the door. I could try on the kick panels, but was wondering what others have tried or done in the past.
Old Aug 31, 2008 | 08:31 PM
ttocs's Avatar
ttocs
If you replaced the deck already, you can wire it into the bypass hrns that I point to on page2 of my cardomain page. Now connect your new speakers to the tweeters signal wire and you have completely bypassed the amp with out pulling a single wire.
If you have not replaced the deck then you will need to find a 5 x 7 or 6.5" 8 ohm speaker.
PaulH2
20
Jan 31, 2016 09:48 AM
Sep 25, 2015 06:58 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
