Audio
Old Feb 16, 2009 | 04:37 PM
ford06's Avatar
ford06
Question Adding subs to a Shaker 500
I have a 06 mustang with a shaker 500 and would like to add on my subs from my old car. Is there any way to hook the subs into the shaker 500?
Old Feb 17, 2009 | 12:03 AM
ttocs's Avatar
ttocs
yep..
Old Feb 17, 2009 | 07:54 AM
ford06's Avatar
ford06
Question How to add subs
Do you need to buy a special adapter from the dealership or from store?
Old Feb 17, 2009 | 10:13 AM
ttocs's Avatar
ttocs
some amps will have an input section that is labeled "high input". This is made to be connected straight to the speaker wires on your existing stereo with out any adaptor. If your amp does not have this option, or if you do it and it makes noise then you need to get what is called a line output converter(LOC). This will connect to your factory speaker wires and will then allow you to run an rca cable from the loc to the amp.
Old Feb 17, 2009 | 05:46 PM
ford06's Avatar
ford06
Default Subs
Thanks for the help, I'm going to try it.
JoshyGT
Sep 19, 2017 08:52 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
iamgobono
Sep 3, 2015 12:37 PM
iamgobono
Aug 16, 2015 10:50 PM
JJ94GT
Mar 18, 2004 09:30 PM
