factory to aftermarket sub help
Old Mar 9, 2009 | 12:56 PM
siberian.mist's Avatar
siberian.mist
Default factory to aftermarket sub help
jus ripped off all the panels surrounding 01 navigator sub. the speaker wires connected were those normal ones that just slide off the clips. but the aftermarket (rockford p1) sub doesnt have the same type of thing to connect the speaker wires. do i need to buy new wires? can i jus snip the metal part off and feed the wire through? the manual tells me nothing about how to connect the factory wires to this new sub.
http://pepsiauto.co.nz/1/55.jpg
Old Mar 9, 2009 | 06:58 PM
flood41's Avatar
flood41
yes you can do that. it will be just fine. make sure to take the plastic cover for the magnet of the p1 off. and you may have to trim the back of the factory encloser, where the bolt for the factory sub was. just trim it down till the new one fits, then use some abs plastic or something close to fill in the hole. glue that down and make sure you seal it up good. hope this helps ya
Old Mar 9, 2009 | 10:46 PM
siberian.mist
oh **** i forgot to take the plastic cover off the back of the sub.. ****... was such a pain getting all those panels back on too.. how is that going to affect the sub? it sounds like its quieter than the stock one was.
Old Mar 10, 2009 | 09:31 PM
flood41's Avatar
flood41
if it fit then don't worry about it. i just suggested it to help make a little more room.
Old Mar 11, 2009 | 05:27 PM
ttocs's Avatar
ttocs
you will not be happy replacing the stock subs unless you add an amp to power them. The factory sub amp does not like to push aftermarket equipment.
Granatelli Sales
Jan 20, 2020 12:34 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
