Is This Possible?
Old Jun 21, 2005 | 02:43 PM
97BlackStang's Avatar
97BlackStang
Default Is This Possible?
I have two punch subwoofers and the mach 460 stereo. Right now i cant afford a good amp to drive them, and i was wondering if it was possible to use the amps from the MACH to drive the subs?!.
Old Jun 21, 2005 | 02:52 PM
ChristopherCamel's Avatar
ChristopherCamel
Default RE: Is This Possible?
Try it....if it works then good for you..if not you need a more powerfull amp...what watt are the subs and how powerfull an amp you got?
Old Jun 21, 2005 | 02:59 PM
97BlackStang
i dont have an amp right now and the subs i think are 125 watts rms, but i wouldnt know what wires to hook it all up to, wiring diagrams would be helpful!
Old Jun 21, 2005 | 03:13 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Nope, wont be a good idea. If you splice into them your gonna drop the ohm load the amp see's and your gonna fry the amp. If you wire them in series then your gonna get half the power output of the amp divided by two for each speaker, meaning not enough power to the subs for them to play right and your other speakers won't play as well either.
Get another amp just for the subs. You'll also need a line out converter to get signal to your new amp from your head unit.
Old Jun 21, 2005 | 04:30 PM
97BlackStang
Thats what i was thiking would happen o well ill just let em sit, or sell them and keep goin with the performance stuff, i tried.
