Sound System
Old Apr 29, 2009 | 05:32 PM
acepilot13's Avatar
acepilot13
Arrow Sound System
Ok, so i have an 09 v6 Mustang and I want to upgrade the sound system. What setup would you guys? I plan on spending around 3000 for the whole thing.
Old Apr 29, 2009 | 10:36 PM
pentavolvo's Avatar
pentavolvo
Start with a nice double din with or without navi as your source unit I recommend a kenwood. Then do some nice coaxials front and back, or components up front if you want to cut a hole for the tweeter. Depending on how loud you want to get either get a 5 channel, or a 4 channel and a mono amp and then its up to you. 1 12, 2 12s, 2 10s etc
a nice system can be had for 3g easily
Old Apr 29, 2009 | 10:47 PM
GeritGoul's Avatar
GeritGoul
what are all the sizes of the speakers?
Old Apr 30, 2009 | 09:20 AM
GTRedfire03's Avatar
GTRedfire03
factory Speakers 4-5x7(6x8), Woofers 2-8"
Old Apr 30, 2009 | 01:12 PM
baddog671's Avatar
baddog671
If I had that setup I would just buy 4 really nice coaxial speakers to keep it simple, no need to throw in 2 component sets. And remove the stock 8s for a set of higher-end 8s. Those subs are probably pretty small (depth wise) since they are in the doors, but they make "slim subs".
Decent 4channel amp for the speakers (screw the factory amp), and a decent 2channel for the subs.
That'd put you well under 3k, and if you'd want more bass you can just throw in a 12 in the trunk...
Old Apr 30, 2009 | 01:32 PM
daragez's Avatar
daragez
speakers size, amplipier, sub woofer...!!! boss is the best...
Old Apr 30, 2009 | 01:34 PM
GTRedfire03
BOSS? ahhh do you mean BASS?
I hope you dont mean the company boss?
Old Apr 30, 2009 | 01:46 PM
GeritGoul's Avatar
GeritGoul
should i have someone install the amps and wire it or is it possible to do on my own without messing it up and with little to no expirience?...im good at figuring things out as long as they arent too difficult.. :/
Old Apr 30, 2009 | 01:50 PM
GTRedfire03
No its easy.....on a scale to 1 to 10 its about 4, if you never have done it. We can talk you through everything....I would say the harding this is getting the power wire through the firewall, and even that isnt hard.
Old Apr 30, 2009 | 10:21 PM
acepilot13's Avatar
acepilot13
thanks for all the suggestions guys
