Deck Problem??
Old Jun 29, 2005 | 03:07 AM
razarr69's Avatar
razarr69
Default Deck Problem??
when im listening to music the odd time the lyrics will cut out n my sub will jus keep poundin. i usually have to turn my deck off then restart it. what wud this be from?i have a sony amp running 2 5x8s, and 5 inchers. then a us acoustics amp runnin my 12 inch cerwin vega sub. wud my problem be with the wiring?
Old Jun 29, 2005 | 04:58 AM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: Deck Problem??
do you have a bass tuner? (a **** that adjusts amp power to subs) if so, turn it down to about 1/4 way up and play with the gain on your amp too....
Old Jul 9, 2005 | 10:57 PM
razarr69's Avatar
razarr69
nah i dont have one i jus played wit the gain on my amp n run tha level of bass thru the deck. it only does it sumtimes tho i dont konw what it would be im guessing it a bad connection or a trippy fuse.
Old Jul 10, 2005 | 09:27 PM
benswords's Avatar
benswords
How did you hook up the amp pushing your components? You could just have a loose wire somewhere, but if you can turn it off and back on to fix it, then I'd tend to think that's not the problem.
Seanam
Oct 4, 2015 10:15 AM
vbonina
Sep 22, 2015 08:31 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TimeLord101
Sep 4, 2015 09:27 AM
