Help: Rear Speakers
Old Jun 30, 2009 | 09:27 PM
Oktober's Avatar
Oktober
Exclamation Help: Rear Speakers
Hello all,
I bought my first Mustang (2000 vert) over a month ago and have noticed the speakers didn't sound quite like they should. I decided to check the speakers in the back and noticed that only the tweeters were working. My stang came with an aftermarket HU already installed so I checked the harnesses that were installed behind it and also the fuses underneath the dash. Everything looked fine so I decided to search the back of the car for a problem. As of right now I've taken the seats and side covers off, but I've noticed these two small "connectors" that are located underneath the rear seat. Nothing is connected to them and I have no clue what they are used for. Anyway, I've disconnected the speakers and reconnected a new set...still nothing. If anyone could help it would be greatly appreciated!
Forgot to add that my system is the Mach460.
Old Jul 1, 2009 | 09:29 AM
ttocs's Avatar
ttocs
that connector is probably for the keyless entry programming.
If only the rear subs are out then I would start by checking fuses. No, I do not know which one and it will take less time to check every fuse then it would to try and figure the manual out.
Old Jul 1, 2009 | 04:09 PM
Oktober's Avatar
Oktober
Thanks for the reply ttocs! I've checked all the fuses underneath the hood and dash, none have any problems. After reading through old threads here I decided to check the rear amps. Unfortunately, my passenger side amp is dead. I haven't decided yet what to do...but I'm really considering just bypassing them completely.
Old Jul 2, 2009 | 06:54 AM
ttocs's Avatar
ttocs
to bypass the amp you will need to replace the deck and the speakers. You can probably find a used amp for cheap on ebay.
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
Doogie65
Sep 6, 2015 02:55 PM
