installing bluetooth
Old Jul 18, 2009 | 05:51 PM
sandcracker21's Avatar
sandcracker21
Default installing bluetooth
how hard is it to install a bluetooth headset into a HU? the one that hooks onto the visor?
Old Jul 19, 2009 | 08:45 AM
ttocs's Avatar
ttocs
not exactly sure what you mean there. A "headset" will program to your phone but not your radio as long as your phone is blue tooth compatible.
If you mean some kind of hands free system then there are a bunch made to connect to any kind of stereo as long as you know how to wire it. I would recomend going to your local car audio retailer to see about having one installed and what they carry.
Old Jul 19, 2009 | 08:53 AM
sandcracker21
im talking about the kind that sits on your visor and is hard wired to the back of the HU
EDIT: in particular im speaking of the bluetooth attachment for my new Kenwood 6140
Old Jul 19, 2009 | 11:30 PM
ttocs's Avatar
ttocs
the bluetooth modules that are made to hook up to kenwoods will have nothing more then a mic to place by the driver. There are a number of hands free universal kits that have the speaker built in and that clip onto the visor as well.
You will need to get to the back of the radio and run wire up to the visor, as well as possibly hide a module up in the dash. I don't know your technical ability. If you mess it up it should just sound bad or not work, it shouldn't catch fire........ SHOULDN'T........
Old Jul 20, 2009 | 06:37 PM
sandcracker21
has anyone removed that side trim that runs up to the visor, not sure what it would be called. the plastic next to the windshield
does it just pop off?
Old Jul 20, 2009 | 09:19 PM
ttocs's Avatar
ttocs
on most cars it does just pull off although I do not know what year yours is. On newer cars they may hide part of the airbag system up there. The A-pillar trim is not even really neeeded to be pulled off as you can often just tuck the wire behind it.
Old Jul 21, 2009 | 10:48 PM
sandcracker21
mine is an 03 Gt....this used to be in my SIGNATURE...but it would appear my sig has disapeared....hmmmm
Old Jul 22, 2009 | 08:23 AM
ttocs's Avatar
ttocs
yes then the a-pillars do just pull off. As I said you don't really need to and can often just use a flat top screwdriver to help you gently pry it up and tuck it inside. If you do pull it off be carefull that the clips do not catch the wire when you put the cover back on.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
