using the existing wiring?
Old Jul 22, 2009 | 03:58 AM
Bay_Area_Boy's Avatar
Bay_Area_Boy
Default using the existing wiring?
I went to a local shop and they installed a bass tube for me. The installed it using the stock Mach 460 headunit. The tube is self amplified. Is it possible to use that wiring and hook up my own amp and subwoofer?
Old Jul 22, 2009 | 08:20 AM
ttocs's Avatar
ttocs
if you mean to add an additional sub, then yes/no. The signal could be used but more then likely you would need an additional power wire. What do you have in mind?
Old Jul 22, 2009 | 03:07 PM
Bay_Area_Boy
Not adding another sub just get rid of the tube and go with like a 10inch sub and some amp.
Old Jul 26, 2009 | 11:08 PM
Bay_Area_Boy
anybody know? cuz i do not want to go back to the shop and have em BS again
Old Jul 27, 2009 | 12:10 AM
ttocs's Avatar
ttocs
it should be ok to use their wiring as long as you are not going with a much larger amp that would require a larger power wire. You would probably need to look for an amp with high-level inputs on it or need a line out converter.
Old Jul 27, 2009 | 12:30 AM
scheetz83's Avatar
scheetz83
I my self have never played with a Bass tube. But if the shop hooked it up and it works then you should be able to hook up another setup of your choice.
As long as you have the following wires going to the tube you should be fine
--- Large power wire going direct to battery
--- Ground cable
--- Small Turn on wire Probably blue
--- RCAs or speaker leads... With out knowing how they hooked up the amp IE the amp could have Hi level Inputs or they may have put in a LOC(Line out Converter) I used one in my 2005 mustang. I taped into the rear deck speakers.
hopefully Ttocs will confirm or correct or totally shot me down. Which is fine to because he is actually helping me out in another thread about replacing a Mach 460
good luck
Old Jul 27, 2009 | 12:32 AM
scheetz83's Avatar
scheetz83
Talking
Look at that me and ttocs where typing at the same time
Old Aug 29, 2009 | 09:40 PM
Bay_Area_Boy
So I finally got around to taking a picture.
http://i170.photobucket.com/albums/u274/the_superfro/substuff001.jpg
thats all i have for wires. im not tech savy but do want to upgrade from a tube. do i need to go back to the shop or can i try it out myself
Old Aug 30, 2009 | 12:03 AM
ttocs's Avatar
ttocs
looks like they ran an 8 awg wire for power and ground which should be enough wire to power a modest to large sized amp with no problems.
Old Aug 30, 2009 | 12:36 AM
Bay_Area_Boy
thanks ttocs
sorry for the noob questions.just all the installers here wont answer my questions without tryna get me to buy sh*t from them first.
